is a b16a2 a good engine to turbo?
Old Mar 21, 2005 | 12:08 PM
crazy4396063's Avatar
crazy4396063
honda
Default is a b16a2 a good engine to turbo?
Hi i just dropped a b16a in my del sol two days ago and i already want to start putting mods on it........should i just turbo it or should i build it from the ground up NA give me some ideas guys!! :screwy:
Old Mar 21, 2005 | 12:13 PM
teg92's Avatar
teg92
WHAT OK YEAH!
whats ur budget?
Old Mar 21, 2005 | 04:43 PM
crazy4396063
honda
well i already have the garrett t3 turbo and intercooler i just need some mandrel bended pipes and a b.o.v and to figure out a fuel delivery system. but my knowelge is limited to what a stock b16a can hold. i can spend about 3-$450 more
Old Mar 21, 2005 | 05:04 PM
teg92's Avatar
teg92
WHAT OK YEAH!
well if you already have the tubro might as well just put it on. Do some research on what other parts you need and just piece it together
Old Mar 21, 2005 | 06:18 PM
b16ahybrid's Avatar
b16ahybrid
What are the specs on the turbo? If it's a small t3 it's going to fall flat on it's face in the higher rpm. I used a t3 (.42/.48) on my b16 when I first swapped it in (that turbo was on my sohc). It pulled ok up to vtec then woulod fall flat on it's face. By redline I would have only about 2-3psi of boost from 9psi.
With a budget that small I would recomend that you wait until you can get more funds together, you don't want to skimp on the tuning portion. Invest in the tuning if you want that motor to last.
Old Mar 21, 2005 | 06:22 PM
30psiciv's Avatar
30psiciv
www.speeddreamz.com
B16 is good to about 12-14psi for extended periods. The ringlands are prone to break and the rods are very narrow at the neck. Believe me, we have pushed stock bottom end b16 to the limit several times just to see what they could take. Put a good set of rods, pistons, block guard, and a fat tune and it will do 20psi safely.
Old Mar 21, 2005 | 06:47 PM
crazy4396063
honda
enough said im gonna sell my turbo and go for cams and other good stuff.....what you guys say to that?
Old Mar 21, 2005 | 06:49 PM
Snoopy's Avatar
Snoopy
been there done that
so you want to build it NA?
Old Mar 21, 2005 | 08:34 PM
b16ahybrid's Avatar
b16ahybrid
When will people realize that psi is NOT a limiting factor of a motor. 12-14psi on a small t3 is nothing like 12-14psi on say a sc-61.
Old Mar 22, 2005 | 03:45 AM
crazy4396063
honda
yea what would be a good idea to build it up NA.?
