Oil Pressure Gauge
Old Mar 6, 2005 | 05:12 PM
copperfox's Avatar
copperfox
nubsos
Default Oil Pressure Gauge
I have a d16z6 in my 95 si.
Should I order an autometer electrical oil pressure gauge or a mechanical one?
I know I will have to tap into the oil pressure sending unit on the back of the block, and I plan to order an oil take-off fitting form tuner toys. Help?
Old Mar 6, 2005 | 06:45 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
I have a mechanical one because they are cheaper and I don't mind the thought of hot motor oil coming into the engine compartment. If you do mind, you should spend the extra money for the electrical one. You will need to tap the oil sender in the back anyway, so the type you get is just a moot point. You could also check out Greddy's oil filter sandwich thing they make that goes between the oil filter and the block and has several different taps for an oil feed line and oil pressure guage line.
Old Mar 9, 2005 | 06:57 PM
civicon19s's Avatar
civicon19s
That fitting looks like an AWESOME product. BUY that
Old Mar 9, 2005 | 10:21 PM
Provocateur
On permanent hiatus
I don't know if you can just have it so that one of the holes in occupied. Maybe there is a plug or screw you can put into it so it can just be used for a guage. Those would be most ideal for a turbo since tapping the oil supply at the oil pressure sender can be a bitch.
Old Mar 11, 2005 | 01:58 PM
Gocartracer's Avatar
Gocartracer
I am using a pressure manifold. Its a billet aluminum manifold that allows me to plug in my stock oil pressure sending , my autometer sending unit and a supply line to my turbo all in one central area. Pics available by email.
Old Mar 11, 2005 | 02:23 PM
olly-civic's Avatar
olly-civic
do you think i could pull my turbo feed off one of them gredy sandwich thingys(thats what we'll call um, lol)
Old Mar 11, 2005 | 06:47 PM
Provocateur
On permanent hiatus
That is what they are made for. It eliminates the need for tapping of the stock oil pressure sensor to feed the turbo.
