oil pressue
Old Mar 6, 2005 | 02:05 PM
hippydib's Avatar
hippydib
hippydib
Default oil pressue
hello all
can anyone tell me if the u.k integra type r has a oil pressure sender unit as standerd fitment.the thing is i have just got an oil pressure gauge wired in apart from connecting to a sender unit.any help would be great.thanks alot
Old Mar 6, 2005 | 03:51 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
The stock oil pressure sending unit only senses when the oil pressure is low, it doesn't tell you how much pressure the system is actually at. You will need to install an oil pressure sensor if you are looking to hook an electrical oil pressure guage up to your car.
Old Mar 7, 2005 | 02:19 PM
hippydib's Avatar
hippydib
hippydib
hello
thanks for the reply.ok ill haveto get a sender unit.thanks again.keep chilling
Old Mar 7, 2005 | 08:32 PM
Provocateur
On permanent hiatus
No problem. Good luck.
Old Mar 8, 2005 | 03:17 PM
civicon19s's Avatar
civicon19s
Just make sure you mount the sending unit to the firewall and NOT directly to the block.. word to the wise!
Old Mar 8, 2005 | 05:27 PM
Provocateur
On permanent hiatus
I have mine mounted to my block with no problems at all. If you really want to make it no hassle, get an oil filter sandwich from Greddy that gives you ports to plug those things into without having to fuss with the oil pressure sensor.
Old Mar 9, 2005 | 06:51 PM
civicon19s's Avatar
civicon19s
id be really careful about the block thing... I tried it that way first with my autometer setup. after a couple hundred miles, the t fitting i was using broke off inside the block! not a fun time
