help!!rear suspension bolt!!!
Old Feb 27, 2005 | 06:08 AM
lubas's Avatar
lubas
Default help!!rear suspension bolt!!!
hi guys,does anyone know how to get the bolt out that goes through the rear fork on the bottom of the damper on an eg hatch?its the only bolt left!! thanks
Old Feb 27, 2005 | 11:47 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
You need a big ass breaker bar or some air tools. I had issue with that bolt too and the breaker bar saved me.
Old Feb 27, 2005 | 02:13 PM
teg92's Avatar
teg92
WHAT OK YEAH!
happend to me about 3 different times, That damn bolts seizes on the bushing and does not want to come out. an impact gun will sometimes work if not a braker bar like "shmoo" said.
Good Luck
Old Feb 27, 2005 | 02:15 PM
lubas's Avatar
lubas
yeah i got an air gun but it aint havin it either,braker bar it is!!
Old Feb 27, 2005 | 02:17 PM
teg92's Avatar
teg92
WHAT OK YEAH!
try that braker bar but be careful cause you dont want to snap that bolt then you would have to drill it out
Old Feb 28, 2005 | 06:15 AM
lubas's Avatar
lubas
oops!!! drill it out it is then!!!lol i think it was the only option anyway,i've been trying to undo it for two days!!
Old Feb 28, 2005 | 11:10 AM
B16a2VTIguy's Avatar
B16a2VTIguy
Built B16a
Default damned bolt!
You'll really struggle to drill thru that bolt......trust me i've been ther!! I tried drilling, heating, impacting etc and it wouldnt budge, so instead i dropped the strut down bent the fork on the strut and squeezed the lower sus arm out, with this out, i put a socket over the outer metal edge of the bushing and used a bearing press to push it out, with that out use the press to put a new bushing in and re-assemble.
This has happened to me 4 times!!
Hope this helps you!
