b18b block help!
Old Feb 16, 2005 | 07:27 PM
IcY's Avatar
IcY
Default b18b block help!
my b18b block is having a knock in it... now ive talked to a few people and they have said rod bearings... but i was wondering if theres anything else it could be thanks in advance
Old Feb 16, 2005 | 10:18 PM
j87w's Avatar
j87w
You could of broke a conrod(unlikely) or broke a rod bolt. What were you doing while it happened?
Old Feb 17, 2005 | 02:13 AM
oldschoolimport's Avatar
oldschoolimport
my 91 integra lsse started knockin, and it turns out my #2 con rod was shaped like a fish hook, the rod cut a notch in the bottom of the sleeve and the bottom of the piston was bouncing off the counterweights on the crank.
Old Feb 17, 2005 | 03:16 AM
IcY's Avatar
IcY
say it is the con rod... will there be damage to the block or can i just replace the con rod
but is rod bearings a good chance on what it may be???
Old Feb 17, 2005 | 05:11 AM
oldschoolimport
when I bent the rod, the bottom of the piston was worn down by the crank counter weight, so there was aluminum smeared on the counterweight, the rod wore a notch out of the bottom of the sleeve, which cut 2 grooves down the piston skirt. basically I saw the need for a piston and rod, honing the cylinder, and making sure that the smeared metal on the counterweight wouldn't seperate and float around in the motor.
I just found another motor, cause at that point in my life I had more money than time. good luck!
