B20 Sort Block With Ls Head? Help!
Old Feb 13, 2005 | 04:06 PM
bluespeed33's Avatar
bluespeed33
Default B20 Sort Block With Ls Head? Help!
Hey im building my LS and i might work on another engine to drop in later. I want to stay non-vtec how hard would it be to put a b20 block in the car, with my already built LS head? also ive heard numerous things about b20 cams and LS cams... which are better anyone have the specs? would it be better to put LS cams in a b20 or b20 in LS. thanks!
Old Feb 13, 2005 | 04:48 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
I think the B20B, B20Z and B18B1 cams are nearly identical in lift and duration.
If you're looking to go all motor, I'd look at the Crower 403s.
Moved to Engine Tech.
Old Feb 13, 2005 | 06:50 PM
dubcac's Avatar
dubcac
I
The LS and B20 cams are pretty much identical, as are the heads. You won't see any gains from switching stock heads between the LS and B20.
Old Feb 13, 2005 | 07:49 PM
b16ahybrid's Avatar
b16ahybrid
The b20 block will bolt right in like the b18 block, simple swap.
