Weird vibration
Old Jan 30, 2005 | 10:06 AM
cdowney00's Avatar
cdowney00
Default Weird vibration
Hey guys,
My 95' SE integra just started making this weird vibartion. The vibration comes and goes once a week or so for the last three weeks, and typically will last 100 miles on a highway, going in between two cities. The vibration only accures when the clutch is engaged and I am hitting the gas. The vibration is also directly related to how much gas I am using. And whats weird is it will just stop randomly on the highway. I thought it might have been a bent rim or rotors but the car doesnt vibrate most the time and when it is vibrating its only when the engine is engaged. If i but the engine in neutral and rev the engine I get nothing. My only guess is the vibration is coming from somewhere in the drive train but I have no clue what it could be. Any help would be great.
Thanks again
Old Jan 30, 2005 | 10:19 AM
hondamastertech's Avatar
hondamastertech
Check the inner CV joints for play and wear.
Old Jan 30, 2005 | 05:55 PM
j87w's Avatar
j87w
I have the same problem, I put in Polyurethane motor mounts, and put in new CV shafts and it went away. Now its just a slight vibration and I cant figure it out.
Old Jan 31, 2005 | 03:18 PM
SmutWanter's Avatar
SmutWanter
"Made to Please"
Yeah, it might be one cv boot, or the whole axle.
Old Jan 31, 2005 | 05:52 PM
cdowney00's Avatar
cdowney00
well the vibration is during highway travel not turns. I have had a bad cv joint before and its no the same clicking ' vibration' but I'm going to aamco torrorow to have them look at my transmission.
Old Feb 1, 2005 | 07:48 AM
JimBlake's Avatar
JimBlake
That's the difference between inner & outer joints. Inners can do just what you described at first.
Old Feb 1, 2005 | 10:17 AM
12yearhondatech's Avatar
12yearhondatech
When the inner cv goes bad you will get a vibration only when you apply gas, try driving the car at freeway speeds and letting off and on the gas every now and then if the vibration goes away when you let off of the gas pedal then you have a bad inboard cv the question is which one the lt. or rt. cv look at both inner cvs and most likely one or both have spun out the grease if only one is leaking then that is the one that is causing your problem. Try this you dont need to remove the axle take the big band off the inner cv and put in new cv grease if you have the band you can reuse first wrap electrical tape 2-3 times around where the big cv band goes and put then put the band back on this makes the band tighter on the boot if you dont have a reuseable band go to the auto parts store and get a new one.
Old Feb 2, 2005 | 10:00 AM
cdowney00's Avatar
cdowney00
Yeah the guy at the shop says its a bad cv axle. Hopefully this will take care of the problem.
Thanks for the help
