No Heat
Old Jan 29, 2005 | 10:35 AM
EDHARRIS's Avatar
EDHARRIS
Default No Heat
Heelo all, I have a 1992 accord ex that I just purchased. The car has 185k miles. The problem I am having is the car has no heat, even after warm up. The heater core is open because I can blow air through it. I think it may be the water pump. Any help would be greatly appreciated. The thermostat has been replaced.
Old Jan 29, 2005 | 12:09 PM
Kai's Avatar
Kai
Rotorphile.
First things first... check the coolant level.
Old Jan 29, 2005 | 12:13 PM
EDHARRIS's Avatar
EDHARRIS
Coolant level is full, and with no air in the system. Thanks for the reply.
Old Jan 29, 2005 | 12:22 PM
Kai's Avatar
Kai
Rotorphile.
Have you checked the heater valve? If it doesn't open, hot coolant won't flow through the heater core.
Old Jan 29, 2005 | 02:47 PM
EDHARRIS's Avatar
EDHARRIS
Yes, the valve is open.
