Vtec Wont Start
Old Jan 27, 2005 | 02:16 PM
vteclost's Avatar
vteclost
Default Vtec Wont Start
I Have A 94 Accord Ex The Engine Cranks It Has Spark It Sputters A Little Every Now And The Butr Wont Start Can Someone Help Me,almostr 200,000 Miles
Old Jan 27, 2005 | 02:33 PM
b16ahybrid's Avatar
b16ahybrid
Have you done a tune-up lately?Start there it's a god starting point
Old Jan 27, 2005 | 03:26 PM
vteclost's Avatar
vteclost
I Changed The Plugs New Wires ,new Rotor ,it Sparks But Wont Start
Old Jan 27, 2005 | 04:30 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Fuel filter? Start with what you have: do you have compression? do you have fuel? do you have spark? do you have air? You are likely missing one of those for it not to start at all. gl
Old Jan 27, 2005 | 06:30 PM
b16ahybrid's Avatar
b16ahybrid
Did you make any changes prior to ths problem?
does your fuel pump prime when you turn the ignition key?
Old Jan 27, 2005 | 08:59 PM
vteclost's Avatar
vteclost
I Have Fuel ,has New Fuel Filter ,has New Plugs, New Rotor, New Wires,it Has Spark It Wants To Start, The Plugs Are Wet,it Has Fuel Pressure, I Havent Checked Compression Yet , But I Have Cranked It For A While And The Number 1 Plug Is Fouled But Number Three Is Still Wet With Gas I Do Not Think Its Firing But It Has Spark,does Any One Know If The Distributor Has A Module Or Is The Ignitor The Module And Can You Test The Ingnitor And What Is Its Main Purpose Of It I Am New To Hondas
Old Jan 28, 2005 | 06:58 AM
JimBlake's Avatar
JimBlake
If the ignitor were bad you wouldn't have a spark. You did say you checked & it has spark, right?
(Most other carmakers call it an ignition amplifier or something like that.)
Old Jan 28, 2005 | 09:26 AM
westcoaststyle
I too am questioning the spark. What tests have you done to determine that the spark plugs are sparking?
Old Jan 28, 2005 | 04:23 PM
vteclost's Avatar
vteclost
I Have A Spark Tester And I Checked Every Plug Wire At The Plug And It Sparks,i Pulled Out The Plugs Attached To The Wire And It Sparks, I Even Checked It At Night To See The Color Of The Spark And It Is White
Old Jan 28, 2005 | 04:24 PM
vteclost's Avatar
vteclost
How Do You Check The Timing On These Engines
