thoughts on ctr OS pistons
Old Jan 2, 2005 | 02:04 PM
pomansouth's Avatar
pomansouth
Default thoughts on ctr OS pistons
i need some thoughts on these badboys, are they good enough to put into a ls/vtec that is pretty well built. I personally dont see anything wrong with using these, i mean why would I need forged, im not boosting. come on guys, learn me something here!!
Old Jan 2, 2005 | 02:28 PM
Snoopy's Avatar
Snoopy
been there done that
whats the rest of your setup?
Old Jan 3, 2005 | 06:38 AM
pomansouth's Avatar
pomansouth
its all decisional as of right now, i am trying to put together a low 13 sec ls/vtec to go into my ej1. Right now, i am thinking omni power valve trane, eagle h-beam rods, undecided pistons, and probably gonna run the stock cams for about a month. I was thinking about girdeling the bottom end, but I am getting a golden eagle guard. There is so much controversial stuff, thats why I am asking about the pistons, maybe I should go with an aftermarket company.
Old Jan 3, 2005 | 11:27 AM
Snoopy's Avatar
Snoopy
if you're trying to keep the stock bore and get as much compression as possible, ctr's will do that for you.
Old Jan 18, 2005 | 02:07 AM
PHiZ's Avatar
PHiZ
BOOST GOD
That is going to be pretty hot compression for a street motor. The P2T pistons are a good choice too. or P73 for even a little lower.
Use the C-speedracing.com compression calculator...
-PHiZ
Old Jan 18, 2005 | 10:19 AM
qtiger's Avatar
qtiger
What head
Old Jan 23, 2005 | 11:34 AM
pomansouth's Avatar
pomansouth
its a b16 head, phiz, are you saying that I shouldnt go with 12.5 to one, even if I have hondata? If so, then I guess I will go with maybe an itr piston, which should be the next step down to 11.5:1 if i remember correctly.
Old Mar 8, 2005 | 11:19 PM
bunger78's Avatar
bunger78
-PHiZ
C-Speed is REALLY off when using R pistons, they don't take the compression height into consideration. Use the calculator here:
Calculator
