Injectors for 91 'Teg w/ B16 swap
Old Nov 10, 2004 | 01:31 PM
rjw43's Avatar
rjw43
Default Injectors for 91 'Teg w/ B16 swap
I've got a 91 Integra w/ a JDM B16 swap. I'm looking to pull about 230 HP out of it and was wondering what the best injectors for it would be? Obviously, I got the ECU when I did the swap. I talked to Venom about their HP injectors and they don't seem to know much when it comes to engine swaps. They said the real difference between the 2 was whether or not it was low or high impedence. Please advise!!
Old Nov 17, 2004 | 08:58 PM
crxresurrect's Avatar
crxresurrect
Default injectors
is the fuel pump stock or did you put a better one in, because on big injectors you have to lots of fuel. I seen people run 450cc injectors on tubros and i have seen 1000cc injectors to, let me know what kind of fuel pump and maybe i can help you
Old Nov 19, 2004 | 10:39 AM
Kai's Avatar
Kai
Rotorphile.
How do you plan to do that? You're not going to N/A, at least.
Since you'll be running some kind of forced induction, go for something in the 450cc range. You'll definately need something to tune them down, such as a V-AFC.
High power RX-7's often use 1600cc secondarys. One of those flows almost as much as 7 standard B-series injectors.
