Head Gasket?
Old Nov 3, 2004 | 01:13 PM
racerdave's Avatar
racerdave
USAF C-17 Crewchief
Default Head Gasket?
Installing T3 on a D16Z6, the motor I was going to use was a rebuilt D16Z6, but I decided to save it for another project and use my 128k motor that hasnt been rebuilt incase I blow it up....
I wanted to know what head gasket would be best? I heard some are much thicker than others and can change the compression. Would this be a good idea? Or should I get a stock gasket?
In my rebuilt I got a MrGasket top end rebuild kit, and the gasket looked like the stock one... So what should I do?
Old Nov 3, 2004 | 02:21 PM
b18coupe's Avatar
b18coupe
i had a cometic highboost headgasket and it blew in 8 miles, i switched to a OEM honda gasket and it was perfect. good luck!
Old Nov 3, 2004 | 05:59 PM
dubcac's Avatar
dubcac
I
Oem > *
Old Nov 3, 2004 | 09:17 PM
Kai's Avatar
Kai
Rotorphile.
A stock replacement head gasket will be fine.
Old Nov 3, 2004 | 09:27 PM
pomansouth's Avatar
pomansouth
more on the cometic, josh is running a cometic, just remember that. 300 and some odd whp. cometic is a good gasket by this statement but horrible by b18coupe's statment. Personally on a d-series, they are cheaper to build so just go with stock since you know it has been tried.
Old Nov 4, 2004 | 08:54 AM
racerdave's Avatar
racerdave
USAF C-17 Crewchief
Sounds good to me.... Cheaper anyways, thanks for the info B18..
Old Nov 4, 2004 | 09:06 AM
racerdave's Avatar
racerdave
USAF C-17 Crewchief
Oh also, what about a block guard? I have been looking into geting one, they are only 50.00 and look like a good idea, but the holes in it for water flow look to small... I was looking on ebay at them, does anyone have any info on them?
Old Nov 4, 2004 | 10:09 PM
pomansouth's Avatar
pomansouth
ive done some recent research on BG's and it seems as though the best one to go with is a golden eagle. Take a look at it, they look very passive and I think it will do the job. The main prob with any block guard is that they are installed improperly. so besure that it is installed correctly.
Old Nov 5, 2004 | 08:22 AM
racerdave's Avatar
racerdave
USAF C-17 Crewchief
Thanks, thats the one I was looking at, I got Golden Eagle Rods when I had my H23, and they lasted the life of the motor...
Old Nov 5, 2004 | 12:34 PM
b18coupe's Avatar
b18coupe
i used a kms block guard and it worked good, ac auto tech is better
