B16a1/2/3
Old Nov 3, 2004 | 07:35 AM
Ryanscivic2004's Avatar
Ryanscivic2004
Default B16a1/2/3
Hi Im totally new to this forum and wondering if anyone can help me?
I have a 93 Civic lsi and i'm doing a b16 swap, only problem is i've gone and got the 88-91 B16A1! bit pi**ed when i found out! can anyone tell me, instead of getting a cable-hydraulic conversion, is it possible to fit a B16A2/3 transmission to the B16A1 without too much trouble?
also if you have any other info that could make my life easier when fitting the engine it would be much appreciated! Cheers, Ryan.
Old Nov 3, 2004 | 11:10 PM
dubcac's Avatar
dubcac
I
Since your car is equipped with a hydraulic clutch, you can mate a hydraulic transmission to the first gen b16 motor.
Old Nov 4, 2004 | 09:13 AM
Ryanscivic2004
Default Mateing tranny?
How do i do it? dont quite get what you mean by mate the hyd tranny of the old car to the 1st gen b16? will the hydraulic stuff of the old transmission bolt on or will it need modifying? or do you actually mean modify the old tranny to fit on the side of the B16?????
cheers,ryan
Old Nov 4, 2004 | 09:39 AM
dubcac's Avatar
dubcac
I
cheers,ryan
You don't need to modify anything. The tranny will bolt up to the motor, your stock slave cylinder should bolt up no problem.
Old Nov 5, 2004 | 10:20 AM
Ryanscivic2004
Default reply
k, thanks for the info.
will get on the case straight away
cheers, ryan.
