crazy hp :D
Old Oct 30, 2004 | 05:05 PM
Kai's Avatar
Kai
Rotorphile.
Originally Posted by dubster99
What makes you think it was running rich?
The most common cause I see of glowing manifolds is excess fuel burning off in them thanks to low A/F ratios... the manifold acts like a thermal reactor from the old'en days.
If it has been running at high RPM for a while, it could do the same though regardless of A/F ratio. Hell, it could even be glowing from running too lean and pumping excessively high EGT's, but an engine like that, I doubt the tuner would have it running lean.
It's hard to take the picture out of context.
Old Oct 31, 2004 | 01:29 AM
dubcac's Avatar
dubcac
I
That's what I would think. Running lean = higher EGT's = glowing manifolds.
