b18b1 to a b18b?
Old Oct 13, 2004 | 12:31 PM
matthewchr's Avatar
matthewchr
pissed off
Default b18b1 to a b18b?
So i got a motor from the neighborhood auto solon and they sent me a j-spec engine (b18b). They cxan't tell my mechanic how the hell to switch them and there's no shop in the area that has expirience with swaps. The problem my mechanic had with the motor was the crank sensor on the american block (b18b1). he is uncomfortable putting in the new motor without knowing how to swap the sensor. can any one tell me how to change the sensor and what other problems may exsist?
Old Oct 13, 2004 | 12:33 PM
teg92's Avatar
teg92
WHAT OK YEAH!
take the crank sensor out the J-spec one and put on a USDM one that will clip in to your wiring harness
Old Oct 13, 2004 | 12:40 PM
qtiger's Avatar
qtiger
I think the crank sensor swaps with the oil pump, if you're talking about the same sensor I am.
OBD2 car?
Old Oct 13, 2004 | 12:43 PM
matthewchr's Avatar
matthewchr
pissed off
the sensor is opn the usdm motor the jspec has none. the gear pulley doesn't have the teeth that the USDM has will it still work?
Old Oct 13, 2004 | 12:45 PM
qtiger's Avatar
qtiger
Yeah, if the JDM motor doesn't have one then it's the crankshaft fluctuation sensor, and it's part of the oil pump. The oil pumps should be compatible... I'm not sure what you mean about different teeth.
Old Oct 13, 2004 | 12:51 PM
matthewchr's Avatar
matthewchr
pissed off
are you saying the sensor is biult into the oil pump on the jspec?
Old Oct 13, 2004 | 01:23 PM
matthewchr's Avatar
matthewchr
pissed off
what do I need to do in order for the Jspec to work?
