D series motor question
Old Oct 12, 2004 | 03:06 PM
Habeeb's Avatar
Habeeb
Banned
Default D series motor question
I'm getting a 1.6 motor but the piston rings are fried, is it possible to put the 1.6 head onto my 1.5 block...the head is non vtec if that helps and also if it is possible will it have any pros/cons?
thanks in advance for the help.
sorry for the newb question
Old Oct 13, 2004 | 10:55 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Why don't you just change the rings???
Old Oct 16, 2004 | 09:55 PM
Habeeb's Avatar
Habeeb
Banned
because changing the rings requires more money whereas swapping the heads my cuzin can do for free.
Old Oct 20, 2004 | 09:47 PM
jung4g's Avatar
jung4g
Asianalize your car
This depends on which motor you have and what motor you are getting.
Some heads will be better than others...
Old Oct 21, 2004 | 07:36 PM
Habeeb's Avatar
Habeeb
Banned
its a d15 block and im getting a d16 head for it.
thanks alot btw didnt seem like anyone was gonna help me :[
Old Oct 22, 2004 | 11:44 AM
B20powered's Avatar
B20powered
You can't see me
Its a DX block??? The Si and DX head are exactly the same except for the cam so yes it will fit. BUT I believe the DX pistons dont have the same valve relifs as the Si. Yank the head and see if each piston(on the DX) has 4 valve relifs. If they do then it will work.
Old Oct 24, 2004 | 05:02 PM
Gocartracer's Avatar
Gocartracer
Default The head will work ....
I have a 92 CX hatch....when the hg finally blew at 80,000 miles I pulled off the 8 valve head and realized that the pistons are set up for the 16 valve head as well. I then made a call and was able to pick up the 16 valve non-vtec head off a 96 del-sol along with the distributer and intake manifold...
I used the head with the stock cx exhaust and intake and it worked fine with the exception of having to slot the dizzy more to get the timing retarded enough to get it to the stock timing mark. Other than that it did make the hatch respond quicker than the 70 hp it originally had. Now I am almost ready to boost it which will get me closer to the 200 hp mark.
Also make sure that you use the proper timing belt for the head your using.
Even though my block was the 1.5 my head was the 96 1.6 and I had to get the timing belt for the 96 1.6 to work.
JV
Old Nov 12, 2004 | 03:21 AM
agent5568's Avatar
agent5568
JV is right. The best way to do it is to get a cam gear.
Old Nov 17, 2004 | 05:41 PM
Gocartracer
Default re cam gear
The cam gear will work but also keep in mind that you can only retard the camshaft so much. Since my last post I have slotted the dizzy more than enough to get the timing retarded past the factory setting which helps when boosting. My cx is now boosted and as soon as I can get my new o-rings for my rc injectors and alittle more tuning I should be putting down around 180hp at the wheels with the saab turbo I am using.
Remarkably with alittle higher fuel pressure and the stock injectors I am able to boost at 2-3 psi without going lean.
Not bad for a homemade pieced together kit.
JV
Old Nov 25, 2004 | 06:15 PM
illicon2003's Avatar
illicon2003
ive got an aem cam gear if you want it, 60 bucks shipped it's silver and in great shape pm me
