1997 INTEGRA- where is the diagnostic cable located?
Old Oct 5, 2004 | 04:33 PM
Mr. IROC-Z's Avatar
Mr. IROC-Z
Default 1997 INTEGRA- where is the diagnostic cable located?
Hi Guys,
The check engine light came on in my 1997 Integra.
Where is the cable located to check the codes?
I know it is usually located under the dash somwhere, but I could not find any data cables.
Any advice would be appreciated. Please also let me know what the cable looks like (color, size, picture..etc).
Thanks!
Tommy
Old Oct 5, 2004 | 06:30 PM
Relic1's Avatar
Relic1
Teal Hatch Cult Member
you mean the OBD2 plug to plug in a code scanner? or the service jumper?
Old Oct 5, 2004 | 09:29 PM
Mr. IROC-Z's Avatar
Mr. IROC-Z
HI Relic,
Yes, the service jumper.
Thanks,
Tommy
Old Oct 6, 2004 | 07:41 AM
the0ne's Avatar
the0ne
i got a 94 integra and mines under the passenger side dash...
like bottem right of the glove box... min is in a plastic green case..
its all the way over to the right tho
Old Oct 6, 2004 | 07:54 AM
Relic1's Avatar
Relic1
Originally Posted by Mr. IROC-Z
HI Relic,
Thanks,
Tommy
start with this and follow the links.
Old Oct 6, 2004 | 03:20 PM
Mr. IROC-Z's Avatar
Mr. IROC-Z
Hey Guys, thanks for the tips! I found the data cable and got the code.
It turns out it was a code 73 (cylinder 3 misfire..etc).
I rechecked the plugs and cap/rotor and all the wires. It seems that maybe the number 3 wire may have been a bit loose. So far so good...no CEL codes!
Tommy
Old Oct 7, 2004 | 07:46 AM
Relic1's Avatar
Relic1
cylinder misfire is usually from either storing the car for a long time and getting stale fuel in the cylinder or simply getting bad fuel in general. But it could also be an indication of something serious, keep a close eye on the car for a while. If the CEL doesn't come back on in a few weeks you should be in the clear.
Old Oct 12, 2004 | 04:23 PM
Mr. IROC-Z's Avatar
Mr. IROC-Z
Default CODE 73...wtf!
Hey guys...well, the dreaded CEL came back on today. I am a bit
I am going to remove the spark plugs tomorrow and check for fouled plugs. I removed the cap and rotor and that seemed ok.
Any other suggestions on what may cause the code 73?
Thanks,
Tommy
Old Oct 13, 2004 | 07:47 AM
Relic1's Avatar
Relic1
plugs, wires, cap, rotor... I think that covers it.
I'm not sure how the ECU senses that code so it might be something strange... like the crankshaft fluctuation sensor or something like that.
Old Oct 24, 2004 | 04:59 PM
Mr. IROC-Z's Avatar
Mr. IROC-Z
Well guys...after replacing the plugs, wires, cap and rotor two weeks ago, I got the damn CEL again last night! It is the same damn error code 73!
I am at a loss of what else it could be.
Please..any suggestions?
Tommy
