HELP!!!! Problem with injection/ignition when the horn is used
Old Oct 4, 2004 | 06:46 PM
JapCRX-95-B16A2's Avatar
JapCRX-95-B16A2
Default HELP!!!! Problem with injection/ignition when the horn is used
Everytime I use the horn, the ignition light lights on, and the low-throtle jumps to 2000rpm (900 normal), and the cut off get set to 4000rpms (8200 normal). it´s a B16A2 Engine.
Then I need to turn the car off, than on again to get the igntion reseted.
CAN ANYONE HELP ME PLEASE?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!
Old Oct 4, 2004 | 10:48 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Sounds like a short in the system. Use a factory service manual to locate the wires associated with the horn and ignition. Test those to determine the short.
Or don't use the horn.
