Egr????
Old Sep 25, 2004 | 12:30 AM
SamuraiBill's Avatar
SamuraiBill
Default Egr????
What does it do????
Austin
Old Sep 25, 2004 | 04:49 PM
vassil3427's Avatar
vassil3427
Originally Posted by SamuraiBill
What does it do????
Austin
It basically shoots exhaust gases back into your intake manifold to reduce emissions. It does a couple other things, but thats the jist of it.
Old Sep 25, 2004 | 06:28 PM
squee's Avatar
squee
My ECU is reporting code for EGR. Is it saying that the control vavle assembly is at fault? and not the part on my Intake Manifold?
Old Sep 26, 2004 | 08:16 AM
Civic2Scooby's Avatar
Civic2Scooby
what motor?
Old Sep 26, 2004 | 09:51 AM
SamuraiBill
I was reading on one of the posts that you can take it off with no probs is that true ?
Austin
Old Sep 26, 2004 | 10:43 AM
squee's Avatar
squee
h22a
Old Sep 26, 2004 | 06:15 PM
Lager's Avatar
Lager
EGR is a good thing for all vehicles driven on the street.. Exhaust Gas Recirculation. Its purpose is to vent exhaust gasses into your intake manifold to reduce emissions and more importantly reduce the chance of detonation on slight/moderate acceleration. Many people think that this will impare performance.. They are mistaken, it actually improves performance by eliminating the above problems..Now on full accel,, this could cause a performance decrease, this is why the OEM's program into the Fuel injection Map, to eliminate EGR activation.. Concerning your problem,, you can have a EGR lift problem or an EGR Flow problem.. EGR Lift code will tellyou that either the Valve itself is sticking or the vacuum/electrical signal is missing, depending your engine. EGR Flow code means that the ports them selves are clogged and need cleaning..Hope this helps..
Old Sep 26, 2004 | 06:20 PM
Lager's Avatar
Lager
ACK!!! Never remove your EGR Valve!!! #1,, its aginst the Law emission wise... #2 If you have a 1996 and later vehicle you probaly wont pass state emissions, for that matter,, you wont pass ANY state Inspection.. #3,, remember,, EGR is Your friend is daily street driving.. Yor car will ping/detonate then preignite( thats the bad one that blows holes thru your pistons) with out one...
Old Sep 27, 2004 | 11:13 AM
SamuraiBill
the reason I asked is because mine isn't hooked up. So I need to get that taken care of then. I was already putting my car in the shop this week anyway. To get it tweeked.
Oh yeah my state doesn't have emission tests.
Austin
Old Sep 27, 2004 | 06:09 PM
Kai's Avatar
Kai
Rotorphile.
If Honda programs their EGR systems anything like Mazda used to, it only operates at idle. No performance loss.
Not true. Plenty of cars get along just fine without them. The car will throw a code without it, though.
