help!! motor gone mad!!
Old Sep 24, 2004 | 08:24 AM
civic401's Avatar
civic401
Default help!! motor gone mad!!
hey guys, I need help again.. My motor keeps on cutting off right at about 5rpm, and on days were it working okay, the car doesn't start to pull until 7rpm.. I get white smoke at high rpm from first the second gear and in neutral when I rev it up to about 5rpm... please tell me what wrong?? mods, dc sport 4 to 1 header, intake, exhaust, no cat, and jun sprockets (at stock setting).. Thanks in advance!!
Old Sep 25, 2004 | 11:35 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
7 rpms is really low.....
Old Sep 26, 2004 | 07:47 PM
civic401's Avatar
civic401
i just did a compression test and it was 180 across.. spark plug for cylinder two was black, oil black.. i know for sure that oil is leaking somewhere from cylinder two.. my only problem is could it be a bad piston ring or valve ring?? please help..
Old Oct 2, 2004 | 11:39 AM
Human Hybrid's Avatar
Human Hybrid
If the compression test was 180 across...I don't think it would be the piston ring. White smoke...head gasket leak? Getting coolant into your cylinder... Check your coolant to see if it is changing colors..
Old Oct 2, 2004 | 11:39 PM
Provocateur
On permanent hiatus
Was the engine cold when you did the compression test? 200 is normal, so if it was cold, that could be pretty normal.
