stuttering engine
Old Sep 21, 2004 | 11:02 AM
sspire's Avatar
sspire
Default stuttering engine
when cold engine starts up beautifly until the tach starts jumping erratically. while driving, the car tends to buck (no combustion). This has been a problem of mine for a while so i'll take you through all the things i have done to it.
1st try
cap
rotor
this fixed the problem for about a week
2nd try
ignitor
(noticed some casing comming off wires leading to the ignitor)
fixed the problem for about an hour and a half
3rd try
replaced damaged wire going to ignitor
didnt do anything
4th try
main relay
car runs better but tach is still floppin all over the place (not engine)
today i cleaned, disconnected and reconnected the harnesses going to the distributer, as well as jiggleing the wireing going to the main relay. car ran like a champ for like 5 miles and 2 starts then it went back to the same symtoms. what could the problem be?
after replacing the main relay misfires and the erratic tach movment OLNY happen when i hit the gas. when its cold everything works perfectly when it starts to warm up the tach begins to go up erratically (never drops below actual engine speed. after about 5 min of warm runnning i give it some gas and it will bog (misfire)
Old Sep 23, 2004 | 03:30 PM
EK9's Avatar
EK9
i had the same problems as you did too. But how i fixed my problems were taking off the distributor cap off and then took out the rotor in it. You notice inside the distributor there's wires that are plugged inside it. Well as for me i took an aligator mouth and just squeeze the plugs tighter so there wouldn't be any loose movement. Try to see if that might be the case.
