CRX ZC swap questions
I have a ZC motor that I am putting in my 89 CRX HF. I have a DX tranny as well. I was told that I have to use 89 integra axles and a 86-89 jackshaft. I got the jackshaft and the bolt holes don't match up. Wondering what I am doing wrong. Any help would be appreciated. Thank you.
well if your using your DX tranny...you can reuse your HF axles. the 86-89 teg shaft will not bolt up as you just learned and you wont ever use 89 teg axles. if you had the ZC shaft you would use 90-93 teg axles. in your case now id go out and buy DX or SI knuckle assembly so you can use there hub and have a bigger rotor if you would like and go get some SI axles.
goodluck
goodluck
