How Much CFM for a D16Z6?
Old Sep 15, 2004 | 12:16 PM
racerdave's Avatar
racerdave
USAF C-17 Crewchief
Default How Much CFM for a D16Z6?
I need to know how much the MAX CFM is for a D16Z6?
Old Sep 15, 2004 | 12:32 PM
Kai's Avatar
Kai
Rotorphile.
Measuring what? Are you trying to get a turbo size out of this, or do you want to know how much air a D16Z6 can flow?
The latter is an easy calculation.
Old Sep 18, 2004 | 04:05 PM
racerdave's Avatar
racerdave
USAF C-17 Crewchief
I wanted to know how much Air a D16Z6 needs when it is maxed out. I gues you could say it is kinda for a turbo/supercharging aplication.....
Old Sep 20, 2004 | 04:30 PM
qtiger's Avatar
qtiger
I've never seen flow numbers for a d16 head.
Old Sep 21, 2004 | 03:36 PM
racerdave's Avatar
racerdave
USAF C-17 Crewchief
that doesent help me any.....
Old Sep 21, 2004 | 07:53 PM
PHiZ's Avatar
PHiZ
BOOST GOD
Neither does the lack of any details for your question.
-PHiZ
Old Sep 22, 2004 | 05:27 AM
JimBlake's Avatar
JimBlake
1.6 liters at 6000 rpm is about 170 cubic feet per minute.
That's without any kind of pumping efficiency or port flow losses, just displacement, so it's an upper limit.
For FI, you'll use your boost pressure, but remember it's adiabatic compression, so it's not a simple ratio. An intercooler is another story...
Old Sep 22, 2004 | 10:40 AM
racerdave's Avatar
racerdave
USAF C-17 Crewchief
So if I got somthing that could move about 10,000 CFM of air, is hooked to a TPS (throttle positioning Sensor) to adjust the airflow at different RPM, would that increase my HP by much? Also the air temp will be aprox. 40-70 Deg. F.
Old Sep 22, 2004 | 06:49 PM
PHiZ's Avatar
PHiZ
BOOST GOD
I think pressure differential comes into play here, what's that called "headless" ?
-PHiZ
Old Sep 27, 2004 | 05:30 PM
Kai's Avatar
Kai
Rotorphile.
I hope you aren't talking about a leaf blower.
