CVT transmissoin draining.
Old Sep 7, 2004 | 11:51 PM
mjej's Avatar
mjej
Default CVT transmissoin draining.
Yo, anyone have a CVT transmission? just curious because i want to drain the tranmision fluid, and have no clue where the drain plug is.
any sugestions?
Old Sep 13, 2004 | 04:51 PM
cartuner's Avatar
cartuner
jack your car up and support it on jack stands. the Drain plug is on the passenger side on the lowest part of the tranny. It's a plug that a 3/8 ratchet can fit into. loosen it and drain the CVT fluid. Remember you will need about 4 quarts of Honda CVT Fluid, NOT ATF. torque the drain bolt to 36 ft/lbs. lower your car and fill through the tranny dip stick. Start engine, move selector through all positions 3 times, ensuring each gear engages. put gear into park and turn off engine. check fluid to see if it's up to the upper mark. Done
