oil on my spark plug? OMG!
Old Aug 13, 2002 | 09:15 PM
IgOtNOluCk's Avatar
IgOtNOluCk
New on the import scene
Default oil on my spark plug? OMG!
i just bought a 94 civic cx (hatch back) and i went to change the plugs and the third one was driping with oil when I pulled it out, what is that and how can i fix that?
Old Aug 13, 2002 | 10:45 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
It can be one, or a combination of three things that I can think of.
1) The spark plug tube seal on your valve cover for the #3 plug is worn, and oil is getting to it thru the plug tube. This is a pretty easy fix, just get a new spark plug tube seal, and swap out the worn out one on your valve cover.
2) Oil is getting past your valve seals on cyl#3, and into the combustion chamber, which could explain the oil on the plug. If this is the case, replacing a valve seal requires a special tool.
3) Oil is getting past your piston rings and into the combustion chamber. If this is the case, replacing rings requires removing the head and oil pan, and taking the piston out of the block. You may be able to remedy this problem by running a higher viscosity oil, which won't get past the rings as easilly as a lower viscosity oil.
that's all I can think of at the moment.
Old Aug 13, 2002 | 10:56 PM
IgOtNOluCk's Avatar
IgOtNOluCk
hey thanks alot, i bought it yesterday and i gotta tear it apart tomarrow lol
Old Aug 14, 2002 | 05:05 AM
Dave C's Avatar
Dave C
Is the oil on the plug tip (spark gap) or on the plug body?
Old Aug 14, 2002 | 02:17 PM
IgOtNOluCk's Avatar
IgOtNOluCk
its allo over the spark plug,and im gettin naw valve cover gasket put on it with spark plug seals put on it right now
Old Aug 15, 2002 | 05:38 PM
Keda's Avatar
Keda
My vote goes for tube seals. They are easy to fix and fairly cheap. Do this first. It will probably clear things up, and if not, you can the the more $$ stuff next.
Good luck.
Old Aug 15, 2002 | 07:27 PM
IgOtNOluCk's Avatar
IgOtNOluCk
i did the tube seals and it fixed the problem thanks a million
Epoch
May 21, 2006 02:57 AM
LT
Dec 16, 2005 02:19 PM
Polipinay
Jan 25, 2005 12:50 PM
Falkor
Jan 23, 2005 07:20 PM
xxjustimajinxx
Dec 20, 2003 10:08 AM
