Ceck Engine Light???
Old Sep 6, 2004 | 08:30 AM
JaYdM.JnKy's Avatar
JaYdM.JnKy
R.E.S.P.E.C.T
Default Ceck Engine Light???
Yesterday I was hopping on the freeway when in 3rd gear @ 8,000rpm my car sort of cut off & made a pop noise, My car redlines @ 9 grand instaneousley the check engine light came on. I went to autozone to test the code, It read P1259 = which is Immobilizer to PCM siganl error WHAT THE FUK DOES THIS MEAN???
Also when I checked under the hood today I noticed a orange vaccum hose next to the battery against the firewall, that it's plastic top was broken, could I have sucked that peice up? Where does that vaccum line lead to???
Old Sep 6, 2004 | 10:22 AM
turboprelude95's Avatar
turboprelude95
just look at the ecu and if you see the little red light blinking, count how many times it blinks and then check this website to see what your check engine light problems means. http://www.londonautoclub.org/html/t..._CEL_Codes.htm
Old Sep 6, 2004 | 02:26 PM
Human Hybrid's Avatar
Human Hybrid
Sounds like something to do with your power train control module..
Old Sep 6, 2004 | 02:55 PM
JaYdM.JnKy's Avatar
JaYdM.JnKy
R.E.S.P.E.C.T
I'll give this a try!
Old Sep 6, 2004 | 06:24 PM
JaYdM.JnKy's Avatar
JaYdM.JnKy
R.E.S.P.E.C.T
This is what I came up with
Long, Long, Short, Short = 22 correct?
22-VTEC Oil Pressure Switch-Open or short in VTEC OPS circuit, defective VTEC pressure switch, but what does this mean in lamens terms???
Old Sep 6, 2004 | 08:57 PM
turboprelude95
well if you need a manual then got to homemadeturbo.com, then go to forums, then to hybrid/tech, and you should see a thread that has honda manuals for you to download and figure out the problem
Old Sep 10, 2004 | 03:37 PM
JaYdM.JnKy's Avatar
JaYdM.JnKy
R.E.S.P.E.C.T
NO MORE LIGHT!!! PROBLEM SOLVED! for now. Clucth FIXED!!! Now I have a problem w/ my axles & oil pan. The axle won't come out the passenger hub??? I replaced all gaskets valve cover, vtec gasket & filter,exhaust manifold gaskets & oil pan gasket. The pnly problem is I still have a leak around the water pump & tranny??? What's goin on??
SHOULD I TRADE HER IN FOR AN STI????
Old Sep 11, 2004 | 06:01 PM
JaYdM.JnKy's Avatar
JaYdM.JnKy
R.E.S.P.E.C.T
HAAAHAAAAA........ She's fixed!!! w/ new 4-2-1 headers chirpin in 3rd. hehe i'll post pics as soon as I get a camera guys!!! She feels great but the clutch is kinda squishy THAT'S EXEDY FOR YA'!!
