Turbo Vacum Lines
Old Aug 31, 2004 | 07:18 PM
Dose3782's Avatar
Dose3782
Boost is like crack
Default Turbo Vacum Lines
Is there a site or article on the net that has a good refence towards routing vacum lines for a turbo charged b16a? Its an obo 0 car. Any help is appericated!
Thanks
Old Aug 31, 2004 | 08:09 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Depends on the turbo, really. Some turbos have a vacuum line that needs to connect to the compressor housing, others don't. It also depends on what type of wastegate (internal/external) is being used as well as if a manual or electronic or no boost controller is installed. Could also vary depending on whether or not a boost gauge is being used. Additionally, whether the setup uses a BOV will make an effect.
Do you have a picture or more detailed information about your setup that would allow me to further contribute to the information you need?
hih
