Weird idiling & hesitation in acelrating
Old Aug 18, 2004 | 08:48 PM
CPL's Avatar
CPL
Default Weird idiling & hesitation in acelrating
I've been having this problem for awhile now. In the summer time when it is really hot it is a lot worse than in the winter when I hardly notice it only every now and then.
The problem:
During start up , the car would idle fine for about a minute and then would expierience something like when your being choked. The rpm's would be jumping up & down between maybe 300 to 550 rpm's sputtering. After about 25 seconds of doing this the choking would be freed up , rpm's jump a **** a hair past 1,000 then drop down back to normal idling just fine.
Also if I dont wait for the erratic adle to pass and just drive off , I would lose some power upon acceleration never letting off the gas then would just free up surging forward. After driving for a minute or two problem is gone.
I cant figure this problem out cause there is no check engine light appearing where I can just find the code.
Here is a list of what I've done so far:
New pcv
new plugs
1,000 mile old distributer cap ( had an extra)
Timing belt & the rest of the belts changed at 120,000 (currently have 142,000)
Fuel filter changed every 30,000
new sparkplug wires from 10,000 miles ago (NGK blue)
Sea foamed (gas tank , crankcase , & throttle body)
Fuel injector cleaner added to a tank before every oil change
Unplugged the IAC valve and the idle dropped like it was supposed to.( not sure if that really means anything)
Jumped the wires at the ecm for the IAC valve and it clicked. ( good )
Checked if the IAC valve is getting power. ( good )
I cant think of anything else to do. If anyone has any insight to what the problem is please HELP!! TIA.
Old Aug 19, 2004 | 04:19 AM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
have you checked vacuum lines?
Sounds also like a PCV problem
Old Aug 19, 2004 | 08:09 PM
CPL's Avatar
CPL
Have an idea which vacuum lines? Are vacuum line mostly connected to the intake manifold?
I've already changed the PCV. The old one was'nt rattling when I shook it. Maybe I should blow through the hose thats connected to it to see if there is any restriction.
Any other ideas guys.
Old Aug 22, 2004 | 08:09 PM
Holly35's Avatar
Holly35
Throwing a CEL code? Mine threw a 9 (CYP) with the exact same symptoms.
Old Aug 23, 2004 | 10:03 AM
CPL's Avatar
CPL
I wish it threw a code , then I would know exactly what the problem is. I'll look up that code you got and see what it is.
Old Aug 23, 2004 | 10:11 AM
Holly35's Avatar
Holly35
a 9 is the CYP or cylinder sensor...pretty much requires replacing the dizzy.
Old Aug 24, 2004 | 04:56 PM
CPL's Avatar
CPL
I'm sorry bro. I'm either stupid or too old , but what is the "dizzy".
Old Aug 24, 2004 | 05:06 PM
Holly35's Avatar
Holly35
Distributor.....and I'm a girl lol...but only if it IS the Cylinder sensor.
Old Aug 24, 2004 | 07:20 PM
CPL's Avatar
CPL
OOpps!!! Sorry! Hope I did'nt offend you. If I did I'll make it up to you.
Old Aug 29, 2004 | 01:11 PM
jdmb16civic's Avatar
jdmb16civic
I had the exect same problem in my 90 integra and it turned out the the Idle air control motor was going bad. And when u replaced the cap did u also replace the rotor?
