2000 Civic DX (swapping in a 95 LS) Wiring Question
Old Aug 19, 2004 | 07:55 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Originally Posted by Bumnah
99+ civic's got obd 2.1 wiring harnasses.
which do not combine at the strut tower. they run from the engine as one piece all the way to to the ecu.
if i'm thinking it through properly. a 99-00 si harnass would've been done you perfectly fine and then a jumper to go to the obd1 ecu.
but being an ls i'm not too sure. it's too pieced together of a swap to make it easy.
can be done to run, but just a pain in the ass.
ehhhh.. I dunno about the Si harness man. The OBD1 distributor has 2 plugs, OBD2 has only 1. That's the huge difference I believe. The injector clips are different too, but that's an easy fix...
Old Aug 20, 2004 | 06:30 PM
h22afreak's Avatar
h22afreak
IN BOOST WE TRUST.
Originally Posted by honura
no no no. The 94 harness is obd1 he can not use that. you will need a obd2 harness. Then again I have never done this swap b4 so im not 100% sure if I am wrong but I do know that you will not need the 94 harness.
i know that the 94 harness is obd1,but what is he going to do for injector
plugs and among other wiring connections.if you have done as many swaps as
i have done you would know what i am talking about,maybee i didnt explain myself fully enough for that i am sorry.but name the swap ive done it,i am currently working on a k series swap into a 99 civic si which is 60% complete
waiting on harness and axles from hasport.have lots or pics and will post.
Old Aug 20, 2004 | 11:06 PM
j87w's Avatar
j87w
The 94 Teg LS engine he got came with a 94 Wiring harness complete. But if we use that what would be the point in the wiring adapter? I need info from someone who has done the swap so I can know exactly what to do and such.
Thanks
Old Aug 20, 2004 | 11:28 PM
h22afreak's Avatar
h22afreak
IN BOOST WE TRUST.
PM me with phone #.
Old Aug 22, 2004 | 07:43 AM
westcoaststyle
Thanks
You're talking about two different things here. The Engine harness runs from the sensors on the engine to the connectors at the strut towers (which an OBD2 Civic doesn't have). The adapter just runs from where the ECU would normally plug into the ECU harness to the ECU. It changes the plugs so you can plug an OBD1 ECU in. They're 2 different things located in 2 different places.
Old Aug 22, 2004 | 08:49 AM
PHiZ's Avatar
PHiZ
BOOST GOD
I'd keep the chassis harness, and just change the plugs that won't plug in (dizzy, injectors, evap, IAT, Alternator.)
And then extend any sensors that don't reach (IAT, CLNT).
I dunno, it's not really that hard, it's just a matter of being comfortable with it.
Also with the DX, you may have to go from 3wire IACV to 2wire.
-PHiZ
Old Sep 1, 2004 | 10:01 PM
j87w's Avatar
j87w
Sorry to bring up this again. But where are all those sensors located. I found the dizzy, injectors, and alternator. Where are the rest of them? Like what do they connect to like what part of the engine. Thanks
Old Sep 2, 2004 | 08:37 PM
j87w's Avatar
j87w
Old Sep 4, 2004 | 12:18 AM
j87w's Avatar
j87w
bump, ANYONE
