b20b advice
Old Aug 16, 2004 | 04:42 AM
duhjunior's Avatar
duhjunior
From: originally from baltimore maryland but i live in north carolina for the time being
Default b20b advice/questions
I want to change the head on my b20b.....need some advice on which would be best. Im going to be turbo charging the engine so i hear that going vtec would not be the best way....but some people are telling me that a b18 ls head would be good for it or a gsr head even though that they are vtecs....any advice would be helpfull.
Old Aug 16, 2004 | 10:22 AM
jeterkm02's Avatar
jeterkm02
hatchbacks r my anti-drug
get a pr-3 head, off a b16 or a type r
Old Aug 16, 2004 | 01:01 PM
Andy's Avatar
Andy
Hybrid Forum Moderator
Basically right now you have a B18B LS head on the motor. You can covert the engine to VTEC (there is some machining involved and you need to drill, tap and plumb an oil feed line) with any of the VTEC heads. The B18C1 head is a little different and has a smaller combustion chamber (resulting in higher compression with the same pistons) and is debateable but probably one of the most efficent heads. The head of an ITR is just a modified (some porting and a valve job) B16A head. Honda doens't really make a crap head (except the 8-valve Civic CX head I used to have) so any of them are desireable. You don't really need VTEC if your going turbo however. The added lift and duration of a set of VTEC cams is what it is and will make more hp then a non-VTEC but the extra overlap on a VTEC cam isn't as productive on a turbo engine as it is on an NA setup. Long story short, I'd personally rather spend the money on upgrading the bottom end of the engine to withstand more boost (with a turbo, more power is just a crank of the boost controller away if your engine can handle it) than upgrading the head.
Old Aug 18, 2004 | 08:52 PM
WhatNow's Avatar
WhatNow
n00b
i agree with building the bottom end.. and if you did happen to have a tec head.. just disable vtec... other then that yea ls is the way to go
Old Aug 22, 2004 | 09:01 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
:eh:
Disable VTEC? How would you do that exactly?
Old Aug 22, 2004 | 09:13 PM
Civic2Scooby's Avatar
Civic2Scooby
VTEC killer cams???
Old Aug 23, 2004 | 06:19 PM
WhatNow's Avatar
WhatNow
n00b
Originally Posted by westcoaststyle
:eh:
i dunno lol.. i've just heard of people doing that..
Old Sep 14, 2004 | 03:22 PM
99Accolude's Avatar
99Accolude
heavy cars Rule!
umm to disable vtec would just take unplugging the clip. but why would you do that total waste of vtec head. id say if you boosting b20 you must sleeve the bitch lol b20 have girly cylinder walls. cant hold much boost. for the head go with stock b20 head . just buy some valve springs, valves retainers .. ect. but like most people are stating the bottom end is a must man.. concentrate on that or youll see your self looking for a new block.
Old Jan 2, 2005 | 11:34 PM
twinring's Avatar
twinring
you could buy the lost motion device from www.raceeng.com this will disable vtec
Old Jan 4, 2005 | 05:26 PM
bambbrose's Avatar
bambbrose
why you would loose power
