Need Help and input
Old Aug 12, 2004 | 04:07 AM
SuperStar19's Avatar
SuperStar19
Default Need Help and input
right now in my 99 Ex coupe im running a JDM Sir-g with I/H/E, FPR and VAFC2. With that set up alone and STOCK everything else the car runs 14.6s and 14.7s @94MPH. My goal for the car is just to get it into the 13s period without going wild with the motor being that its a daily driven car. I was told that if i install a CTR intake cam, skunk2 manifold and cam gears and tune everything that it will be possible for me to run 13s. Im still running a stock clutch and flywheel in which i wil eventually change. Do you all think 13s is possible?. The reason why i would consider going with this set up is because i know that with skunk cams i will not get their full potential without raising compression which is somthing that I am not ready to do right now.
Old Aug 12, 2004 | 02:37 PM
SuperStar19
