valve cover gasket?
Old Aug 4, 2004 | 07:58 PM
mischif maker's Avatar
mischif maker
Default valve cover gasket?
do i have to apply any type of appoxi or silicon on the gasket? or do i just take the old off and apply the new?
Old Aug 4, 2004 | 08:45 PM
shawn_crx8891's Avatar
shawn_crx8891
i've never used anything like that...i just put it on.
Old Aug 4, 2004 | 08:47 PM
mischif maker
thanks i just bought a 89 accord lx for $ 75 and it runs good but needs a valve cover gasket , could that lead to oil leaking? cuz thier is oil around the headers and it burns ?
Old Aug 5, 2004 | 12:02 AM
shawn_crx8891
that is a possibility. you'd have to look to see where it comes from.
Old Aug 5, 2004 | 11:25 PM
slammed91-hatch's Avatar
slammed91-hatch
you don't need silicone or any sort of sealant. just make sure the old gasket is taken completely off and clean the surface off of all debris before applying new gasket. It could cause an oil leak, you gotta look though, can only tell by being there.
Old Aug 6, 2004 | 06:19 AM
vassil3427's Avatar
vassil3427
Make sure you also get the gaskets for the spark plug well's. Normally if the valve cover is leaking, so are the seals in the plug well's. They also set in the valve cover, very easy to replace.
