60mm exhaust big enough for turbo?
Old Jul 27, 2004 | 07:20 PM
SICK BOY's Avatar
SICK BOY
gsr-t hatch in progress!
Default 60mm exhaust big enough for turbo?
i was wondering if i got a 60mm cat back, would it be big enough for a turbo. or should it be bigger. if so how big?
ps. (very very stupid question) does a cat back system include a hi flow cat?
thanks
Old Jul 27, 2004 | 07:32 PM
SICK BOY's Avatar
SICK BOY
o yeah and what brand or model would you recommend if i didnt want something real loud
Old Jul 27, 2004 | 09:42 PM
Skad's Avatar
Skad
Worst Poster Eva
Cat-Back exhaust is from the Catylic Converter back, so no, doesn't include high-flow cat.
I have no clue about your other questions, but I do hear, that you usually go 3" all the way back when you have a Turbo set-up
Old Jul 28, 2004 | 01:36 PM
Snoopy's Avatar
Snoopy
been there done that
depends on how big the turbo is and how much you'll be boosting
Old Jul 30, 2004 | 07:52 AM
sensei's Avatar
sensei
Turbos like a big exhaust, 60mm is way, way too small. Visualize blowing a golf ball through a garden hose..
Go with the largest turbo back exhaust you can afford. Commercially, 3" is the largest you will find for a Honda. You will be throwing away a ton of power and efficiency by choking it with a 60mm system..
Old Jul 31, 2004 | 07:06 PM
95acrdcpe's Avatar
95acrdcpe
60mm (almost 2.5 i believe) will help the turbo to spool faster if running 7-8 psi maybe a little more....but it begins to suffocate top end esp when cranking up the boost
Old Aug 1, 2004 | 06:30 PM
qtiger's Avatar
qtiger
I'd do at least 2.5" for a turbo setup. 3" for higher power setups.
