94-95 Ls Swap Into 96-up Civic
Old Jul 22, 2004 | 12:54 PM
blueboi69's Avatar
blueboi69
Default 94-95 Ls Swap Into 96-up Civic
Hi, Im New Here. I Have A 94-95 Integra Ls Swap. I Know Its An Obd1 And Im Swaping It Into A 96 Civic Ex Coupe. Im Having Problem With The Wiring Where I Should Cut The Wire From The Engine And Just Rewire The Thing Or Just Use My 96 Ex Harness For The Ls Engine? I Have A 97 Integra Ls Obd2 Ecu And 99-00 Civic Si Motor Mounts ,just Need Help For The Wiring Of The Engine? Any Help Is Appricated?
Old Jul 24, 2004 | 11:01 AM
93civic_FSalama's Avatar
93civic_FSalama
I know this is going to run u some money, but i believe that the worst thing you should do is use a cut harness. You may as well spend the extra money and do it right.
