light knocking noise
Old Aug 11, 2002 | 07:57 AM
excitid's Avatar
excitid
Default light knocking noise
90 si stock engine light knocking noise only during hot weather and after hard driving and cel comes on when I check for codes there are none. Engine smokes a little bit under wot but seems to run strong still. it also sometimes idles below 600 then goes back up to normal. I'm not driving the car anymore but I would like to know if its a big problem or timing related belt seems to be more loose the usuall and I was thinking it could have jumped timing. I don't know if this is even possible. Thanks
Old Aug 11, 2002 | 11:17 PM
AwwsChwA's Avatar
AwwsChwA
Default Re: light knocking noise
my 91 si also makes a light knock sound. Most likely nothing to worry about, could be an injector getting a bit noisy, could be one or two valve lifters just a little bit out of spec, could be one spark plug hitting just a little bit early. Nothing that's gonna cause damage (least that's what the Honda specialists told me)
very unlikely that your engine skipped a timing belt tooth. If that happened you'd feel a noticable power loss at some point in your power band (depending on which way it skipped). The smoking at WOT is probably valve guide and piston ring wear letting just a little bit of oil past the seal. To be expected of a high-miles, well-worn Honda engine. Try putting some Lucas Oil in your oil next time you do an oil change. If it's burning more than a quart of oil in 500 miles, put in one whole quart of Lucas oil, and if it's less than that, just put in a half quart of Lucas Oil. You can get it at Napa Auto Parts, and I'm sure lots of other parts stores, depending on which stores you have in your area.
Old Aug 16, 2002 | 10:40 PM
pimpdaddypat's Avatar
pimpdaddypat
yea man i think you have a couple of problems there...
another thing you mentioned that AwwsChwA left out was the idle movement that could be your idle air controler
and for the code jumping are you using a scan tool or just jumping the wires...
cause if your using a scan tool it will tell you the codes and sometimes say no code found...
but if your jumping the wires i don't know what it would do...
are you jumping them right and what does it do if so...
Old Aug 16, 2002 | 10:44 PM
pimpdaddypat
also the knocking could be a number of things...
1. it could just be the valves hopefully
2. it could be that your low on oil and if you add some it goes away
3. it could be that you spun a bearing
so it can be a number of things
like if you spun the bearing it would also cause the check engine light
and for the smoke like AwwsChwA said its probly your pistion rings do what he said about that lucas oil... it can't hurt to try to help it...
Old Aug 18, 2002 | 04:04 PM
c-c racing's Avatar
c-c racing
im new to the block i have 83 prelude es1 side draft 1.8 i just done anb/ head job and i was informed that you need to readjust the rocker assembly when removing the cam and they say to adjust them every 45 thousand mi::::::::::::::::::::::::::::
Old Aug 19, 2002 | 01:36 PM
AwwsChwA's Avatar
AwwsChwA
and yes, to answer C-C, you do need to adjust valve lash and make sure that the cam is timed with the proper cylinder when replacing a cam. Valve lash on Honda engines *should* be set every 15,000 miles, but you can get away with 30,000 miles without any major noise or power loss.
Old Aug 25, 2002 | 06:07 PM
excitid's Avatar
excitid
I wasn't aware I had to jump any wires to check codes. I was just looking for the flashes. 90 si
Old Aug 25, 2002 | 06:10 PM
excitid's Avatar
excitid
I had the timing checked and set again and there is no noise seems back to normal but I will probably still swap it out. I'm selling my other hatch to my bro so I can finance a new motor.
doIhaveBDIs
CRX & Pre 92 Civic
Aug 9, 2003 01:04 PM
b12uceHuy
Accord
6
Jun 29, 2003 03:02 PM
contij
CL, TL, TLX & Vigor
4
Feb 25, 2003 09:17 PM
fabs
92+ Civic/EL & Del Sol
8
Oct 13, 2002 06:41 PM
Black2KGSR
2
Oct 7, 2002 05:55 PM
