Adjustable cam gears.
Old Aug 10, 2002 | 09:18 PM
Bookshelf's Avatar
Bookshelf
highrevmotorsports.com
Default Adjustable cam gears.
Guys, can somebody explain me how adjustable cam gears work? I know that they are used for timing but I don't know how you actually adjust them.
Old Aug 11, 2002 | 10:02 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
The red center section rotates independantly from the outer section. You loosen the set screws and rotate the red section to a setting indicated on the gear.
Old Aug 11, 2002 | 01:28 PM
Bookshelf's Avatar
Bookshelf
And the red section is connected to the cam, right? Thus, you adjust timing, right?
Old Aug 11, 2002 | 04:15 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Yes, the red section is connected to the cam via the Woodruff key, and the outer section's teeth ride in the grooves of the timing belt. When you move the red section in relation to the outer section, you are adjusting the cam timing.
Old Aug 11, 2002 | 04:36 PM
Bookshelf's Avatar
Bookshelf
Thanks man!!!!....!!!.....!!!...!!!!!..
Nightshade
Feb 10, 2004 05:39 PM
