Skunk2 stage2 cams and milled head?
Old Aug 10, 2002 | 12:03 PM
VtecDA9's Avatar
VtecDA9
Default Skunk2 stage2 cams and milled head?
Anyone know about the clearnace with skunk2 stage 2 cams, a stock head gasket and Ls/Vtec b16head setup... how much i'd be able to mill the head. i'm going to be running .25ITR pistons. I plan to rev to 9000 safely, but want to raise my compression a little more via milling. i was thinking around .020.
Also, how many points for every thousands milled?
thanks
Old Aug 10, 2002 | 07:25 PM
dubcac's Avatar
dubcac
I
My roomate had them with a milled head and JDM itr pistons, and it was fine. But i also do know that with the stage 2 cams you can't separate them by I think 2 degrees, otherwise the valves will hit each other. As for the valves hitting the piston with a milled head
Old Aug 10, 2002 | 08:01 PM
qtiger's Avatar
qtiger
I'd like to put in a quick plug against milling the head for anything other than what is necessary to make it clean and level. Not only do you permanently lose piston to valve clearance, but you have to deal with correcting cam timing and whatnot.
You can get .2 more compression with p30 (JDM b16) pistons, and .5 more compression with pct (CTR) pistons. Both will cost you about the same as p73-00 pistons, give you the compression you want, and you won't have to mill.
Old Aug 11, 2002 | 12:09 AM
VtecDA9's Avatar
VtecDA9
True, but I believe that the p73 pistons are lighter then the p30 and I already have the p73s on machined LS rods. Is it cam timing or igniton timing? I always have to adv. my ignition timing after a milled head because it retards.
Old Aug 11, 2002 | 11:01 AM
qtiger's Avatar
qtiger
Depending on the year of the car, ignition timing may be automatically corrected for, but cam timing will be off.
Old Aug 11, 2002 | 03:52 PM
aut0tek's Avatar
aut0tek
Get a thick headgasket to make up for the milling and u be ok.
Dat's what I did. Otherwise I would've had 13:1 compression lol
Harry
Old Aug 11, 2002 | 06:03 PM
VtecDA9's Avatar
VtecDA9
Harry
Wouldn't that defeat the purpose then. i'll probably jsut clean up .010 to be safe, but get something out of it.
jnaut
May 31, 2007 10:26 AM
BeanSpec
Mar 9, 2006 04:40 PM
TyPe_R_GuY
Jul 7, 2004 08:13 AM
boosted99si
May 10, 2004 02:39 PM
R92680
Jul 27, 2003 01:14 PM
