Engine vibrations
Old Jun 6, 2004 | 06:15 PM
karmaki's Avatar
karmaki
Default Engine vibrations
Hello, I got a problem with my Integra. Problem started as short vibration-shots coming from the engine, now it is vibrating all the time. Vibration is not strong, though sufficient to have the glove compartment or side panel rattle when standing in gear, very very annoying.
Car runs a bit rougher and will occasionally drop dead when startd warm.
Tried to change spark plugs, spark plug wires, distributor cap and rotor, fuel filter, used a clean injector in the tank .... it stayed the same.
Could be the fuel pump behaving weird? Will a fuel pressure gauge say anything about this? Any other idea?
Thanks a lot for any help !
Old Jun 7, 2004 | 10:57 AM
B20powered's Avatar
B20powered
You can't see me
Look at your motor and see if its moving around in the engine bay.
Old Jun 7, 2004 | 11:36 AM
ludeboom's Avatar
ludeboom
if its running REALLY rich i could see that maybe...more likely its a mount.
i have a partially torn drivers side mount and my dash rattles a bit just like you described.
~boom
Old Jun 7, 2004 | 07:42 PM
karmaki's Avatar
karmaki
Thanks for the hint,
it could be the engine mount however the engine running rougher and idle-dip when warm-starting came all along with these annoying vibrations (car was doing great and very very smooth until then), so I really believe it is something with the fuel injection or a kind of misfire, ignition coils ....?
Any additional idea ??? Anybody there had same kind of problem? (..and solved it
Thanks again for your feedback !!
Old Jun 7, 2004 | 08:47 PM
dj_t_ray's Avatar
dj_t_ray
I have a similar issue with my Honda Civic and posted as well, if you get any clues or anything can ya let me know? i'll keep an eye out just the same. thanks.
Old Jun 8, 2004 | 07:56 AM
ludeboom's Avatar
ludeboom
do the O2 diagnostic as per the helms or chiltons, to make sure your O2 heater is operational. the engine runs full rich when cold and accounts for it, but once warmed up it samples the O2 sensor...problem is that when your not making hot exhaust (idling and low speed driving), the O2 sensor isnt hot enough to give a stable output. this is where the heater circuit becomes necessary to prevent the car from running rich.
on the other hand when your on the highway and making horsepower the O2 is above 600*F from the EGT. so it reads accurately...
here: try taking the car out for a spirited drive...ie. get it over 4000 rpms on the highway for a few minutes, beat on it.
pull over
then see if it idles a little better.
if the car idles/runs better after being on the highway...
then it sounds like it could be the O2 heater or the heater circuit.
~kris
Old Jun 8, 2004 | 08:26 PM
karmaki's Avatar
karmaki
.... ok I'll go for a "spirited drive" and see ....
Old Jun 15, 2004 | 01:40 AM
maldini's Avatar
maldini
Is the O2 sensor expensive to replace?
Old Jun 20, 2004 | 09:28 AM
karmaki's Avatar
karmaki
Hello, I guess the oxygen sensor is not really expensive, the part costs somewhere between 30 and 70$ plus labour. However I have tried to warm the sensor up driving "happily" and things did not get any better so I guess there is no real evidence for it to be responsible of my problem..... actually I do believe it is something electrical since vibrations get much worse (stronger and higher frequency) as I turn the vent to maximum !
Maybe the alternator does not give enough voltage or I have a corted element in the battery ?
Thanks-
bboygraphix
Engine Swaps, Tech & Tuning
3
May 7, 2003 07:11 PM
bboygraphix
92+ Civic/EL & Del Sol
11
Apr 29, 2003 05:31 AM
bboygraphix
11
Apr 17, 2003 03:27 PM
kustomdesignz
Dec 16, 2002 09:16 PM
jaje
News & Rumors Archives
13
Aug 27, 2002 09:52 AM
