It's Alive!
Old May 27, 2004 | 08:22 AM
lingerbw's Avatar
lingerbw
Default It's Alive!
I turned the key last night on my first engine project. The results were pretty much what I expected. It started, but ran pretty rough. Here's the rundown:
F22B1 rebuild
Bottom:
Wiseco 11:1 pistons
Stock rods
Stock (replaced) rod bearings
Stock (replaced) rod bolts
Home hone job (green scratch pad)
Top:
Mild head mill (just to flatten after blown head gasket)
Intake ported
Intake manifold port matched
3-angle valve job
All head items are stock
Miscellaneous:
AEM CAI
DC 4-2-1 Header
AEM True Power pullies
Replaced timing belt, balancer belt, and water pump
Added the balance shaft seal retainer
Here's my question: Is it difficult to time this motor? I'm thinking that's why it's running so rough. (I tried just messing with the distributor, but gave up quickly because I didn't want to advance or retard the timing to the point where I caused problems. I'm buying a timing light tonight.) Any other comments or suggestions on what to do next would be extremely helpful.
Thanks,
Brent
Old May 27, 2004 | 02:57 PM
dustimus's Avatar
dustimus
Better golfer than you
why not replace the stock rods??
Old May 28, 2004 | 12:42 PM
lingerbw's Avatar
lingerbw
Anyway, I got it timed, and the valves (I had assumed the machine shop put the head back together to spec... not so.). It's running much smoother now, but I am still having a fairly loud ticking coming from the valve train. Now that all the valve clearances are adjusted to Honda specs, I am really at a loss as far as what I should check next. I should tell you that I retorqued all the cam holder bolts just as a precaution.
BTW, timing was easy :thumbup:
Old May 28, 2004 | 03:01 PM
Daniel's Avatar
Daniel
First I will say, I'm not very well up on the details of getting your engine properly tuned to run at maximum efficiency, but one thing does jump out at me.
You say you adjusted the valve clearances to Honda spec, but did you take into consideration that you're running higher-compression pistons than OEM and as such, your valve clearances may need to change?
Old May 28, 2004 | 06:43 PM
lingerbw's Avatar
lingerbw
Hmm. Good point. I think this enters into the arena of which I am fairly uneducated. I did build the motor, but I was just following directions, basically. Would I need a larger valve clearance for increased compression, or would it be a tighter clearance. I currently have them adjusted to .010" (intake) and .012" (exhaust).
When I went to adjust them there was no clearance at all. I couldn't get a feeler guage between any rocker arms/valves
Thanks for any input and/or ideas on what I should do next.
jlammy
Dec 23, 2003 02:01 PM
sinthetiq
Dec 2, 2003 03:51 PM
Falkor
Sep 14, 2003 06:23 PM
westcoaststyle
92+ Civic/EL & Del Sol
25
Sep 17, 2002 03:10 PM
