gsr-turbo...EMISSIONS!?!?
Old May 24, 2004 | 08:41 PM
procircuitcr's Avatar
procircuitcr
Default gsr-turbo...EMISSIONS!?!?
ok fellas how am i supposed to pass emissions with my turbo b18c1, im only runnin 4 lbs to keep the motor strong but i am nervous about emissions becuause the previous owner ran the car very rich...if i lean up the ratio with my apexi afc should i be alright???
thanx,
-integratard
Old May 24, 2004 | 11:08 PM
Smurf's Avatar
Smurf
Dancing Banana Driver
dosnt realy matter if you live in CA your .... ****ed. Any where else you might be safe. Make sure you cat is new, or well working, and maybe get a custom system for the sniff test, *hint* two cats *hint* I dono, it should pass the sniff with one good clean cat no prb. Many people here have.
Old May 25, 2004 | 08:20 AM
procircuitcr
well i guess i will give it a try thanx man
Old May 25, 2004 | 10:28 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
What year is the car, what state are you in, and does the car have a cat?
Old May 25, 2004 | 11:25 AM
procircuitcr
94 ls chassis with 95 gsr....has a race cat and im in washington
Old May 25, 2004 | 02:21 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Define "race cat." Is that one of those test pipes that's sort of shaped like a cat, but with no actual catalyst inside?
Luckily since the car is pre-'96 you don't have to worry about them scanning the OBDII diagnostic port.
Not sure if they have a visual inspection in Washington state, but as long as they don't then you just need to worry about making the tailpipe reasonably clean.
Mainly as long as the fuel is tuned properly and you have a real cat on the car, you should do fine with a sniffer test.
IntegraGSR707
Drag Strip
7
Jun 2, 2004 10:20 PM
solfreak
13
Nov 5, 2003 11:44 AM
60-1
Jul 25, 2003 06:15 AM
SpeedDriven
Aug 17, 2002 08:07 PM
