OBDII H22 Chipping ECU???
Old May 20, 2004 | 01:48 PM
madmike's Avatar
madmike
Default OBDII H22 Chipping ECU???
ok I own a shop and I never messed with Honda OBDII. I found two 2001 V-TEC H22 engines for sale, but can anyone on here chip these ECU's?
Or can you even run Hondata on these?
They are USDM Accord engines with Automatic, I would not mind having them if I can bolt one on my F23 Five speed, and chip the ECU.
MADMIKE...
Old May 20, 2004 | 08:46 PM
PHiZ's Avatar
PHiZ
BOOST GOD
MADMIKE...
Your best bet is to run them off an OBD1 ecu. That generation prelude ECU has an immobilizer, that cannot always be disabled, unlike most of the other IMM.
-PHiZ
Old May 21, 2004 | 10:16 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Most of the '96-'01 Honda ECUs have their processor and memory joined together as one unit. You can't replace the memory without replacing the processor, which makes the chipping process a bit too expensive and nobody has really bothered to try.
Old May 21, 2004 | 03:14 PM
PHiZ's Avatar
PHiZ
BOOST GOD
Well, sorta.
I mean, without even getting into the underground aspects of it. You can buy chipped OBD2 stuff from JET. (Toda too, but I'm not sure if you can in the US)
I have a chipped OBD2A P2P sitting right here as a matter of fact. Richard has an emulator board that replaces the stock MPU (aka the ThunderChip, haha)
-PHiZ
Old May 23, 2004 | 03:52 AM
98cwitr's Avatar
98cwitr
Where's the DC5R???
Technically OBDII cannot be 'chipped' some companies can do OBDII tuning but it isnt going to give the base map that the OBDI will
OBDII sucks...OBDI owns (ie Hondata tuning available)
Old May 23, 2004 | 09:16 AM
madmike's Avatar
madmike
Default hmm wonder??
Originally Posted by PHiZ
Well, sorta.
-PHiZ
PHiZ ; OK if I run an OBD1 ECU then I am going to have to change the injectors, and what sensors? probally the wire harness? Also these engines are on automatic trans, and I want to use one with a five speed. I would not even consider these 2001 engines but they are at such a good price because no one else wants to mess with OBDII. Will your OBD2A P2P run this engine, and what else would I need??
thanks for all the info PHiZ, I was hoping you would see this....
madmike....
Old May 24, 2004 | 09:21 PM
PHiZ's Avatar
PHiZ
BOOST GOD
madmike....
I don't have the H22 background, I have a B series and D series background.
That being said, an OBD1 prelude ECU should run fine (P13). There shouldn't really be any auto tranny considerations. IN the civic and tegs, there is no modifications neccesary to run an OBD2 motor off an OBD1 ecu. CKP sensor is the same, and everything else is the same.
Do some more research, I'm sure ppl have done this swap a whole bunch, you'll learn the little tricks, like if I remember correctly on 95-96 prelude chassis, they switched pins A1 and A15 or something to do with fuel pumpery. Sometimes IACV is slightly different between motors, and FITV is sometimes different between auto/manual.
Something also to consider, OBD2 prelude ECUs aren't going to do you much good because of the built in immobilizer function, so you'll need the (key?) that matches the ecu (could be built into the key cylinder in the steering column too, dunno.)
-PHiZ
Old May 24, 2004 | 10:50 PM
madmike's Avatar
madmike
Default thanks bro
-PHiZ
Thanks bro, that sure answers all the questions I had, I might just grab one of these, we have to start messing with the newer stuff sooner or later to learn, or we be left behind right???
Old May 25, 2004 | 10:30 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
You can use any number of older ECUs to run the newer engines just fine. It's a lot easier to use an older ECU on a newer engine and just not use a couple of sensors on the engine (because the ECU doesn't look for them) than to run an older engine with a newer ECU (because the ECU looks for sensors that aren't there).
Old May 25, 2004 | 10:10 PM
madmike's Avatar
madmike
Default cool
That sounds like the way I will go, thanks!
4thGenReady2Go
Prelude
3
Oct 12, 2003 12:52 PM
Sleeper00
Accord
4
May 8, 2003 01:04 PM
Sleeper00
Accord
2
Apr 24, 2003 09:24 AM
Ryu
Accord
6
Nov 16, 2002 06:18 AM
fastludeh22
Nov 7, 2002 07:07 AM
