Usdm B18c1 And Emmisions?
Old May 18, 2004 | 09:48 PM
B18C1 HB's Avatar
B18C1 HB
Default Usdm B18c1 And Emmisions?
Whats Going On,
HereS What I Have, I Have A 95 Civic Si Hb With A B18c1 That Has Type R Internals. Now I Have Not Gone To Get It Smoged And I Really Dont Want To Just In Case I Dont Pass, I Live In Cali Which Brings Me To My Question Will I Pass With The The Stock Cat. Any Feedback Would Be Great
~d
Old May 19, 2004 | 06:05 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Assuming your fuel is tuned properly, the engine is from a '95 or newer car, you pass the visual inspection, and the cat is functioning properly...you should pass the tailpipe test.
Old May 19, 2004 | 10:08 PM
B18C1 HB's Avatar
B18C1 HB
i have a little bit of white smoke coming out of the tailpipe when im on it hard and i just put in a new cat could the white smoke be extra gas burning or oil burning
Old May 20, 2004 | 07:17 AM
qtiger's Avatar
qtiger
White smoke is typically coolant.
Old May 20, 2004 | 01:12 PM
H22ATeg's Avatar
H22ATeg
1995 H22A Integra
I had a leaking head gasket in my old integra. The white smoke is the coolant probally. I would check your head gasket. I only had a little bit of white smoke. So it sounds about the same
Old May 20, 2004 | 07:14 PM
B18C1 HB's Avatar
B18C1 HB
the motor was only built 18 months ago and was replaced with new gaskets all the way around
