Compression test ... yikes
Old May 2, 2004 | 12:55 PM
shivers's Avatar
shivers
Moderator Alumni
Default Compression test ... yikes
I borrowed a compression tester from a friend for the heck of it so I could test my car. I pulled the fuel pump fuse, the plug wires, and the spark plugs. Hooked up the gauge and got the following results:
Cyl 1 - 225
Cyl 2 - 225
Cyl 3 - 225
Cyl 4 - 160, 70, 80, 90, 90
The car is a '00 civic si with 43k miles. Only mods at this point are i/h/e/ecu. The car is a daily driver that's been used for a few track days and it's been to the drag strip 10-15 times. I drive the car hard, but it's never abused. The car doesn't burn oil between changes, doesn't puff smoke, and has never felt down on power.
Any ideas on the low compression? I'm going to see if I can do a leak down test sometime this week. I'm getting ready to throw in some CTR cams ... looks like I might be doing a bottom end build-up sooner than expected.
2005 s2000
Old May 2, 2004 | 12:58 PM
KAUAI KANE's Avatar
KAUAI KANE
91' Toyota Supra
From: Iwakuni, Japan. And where ever the Marine Corps sends me
fried the piston rings maybe i :dunno: buthtats pretty odd for a 00' Si though:thinking:
Old May 2, 2004 | 01:49 PM
shivers's Avatar
shivers
Moderator Alumni
That was my first thought too, but since there's no blue smoke coming out of the exhaust, I didn't think it was the rings. :dunno:
All the plugs looked good too, so I'm really at a loss.
2005 s2000
Old May 2, 2004 | 03:46 PM
sensei's Avatar
sensei
Test one of the "good" cylinders again to make sure that the schrader valve on your compression tester didn't get stuck open...
Old May 2, 2004 | 04:53 PM
shivers's Avatar
shivers
Moderator Alumni
Thanks. Tested Cyl #1 two times. Got 225 and 220. I guess I could try another gauge and see what happens.
2005 s2000
Old May 2, 2004 | 05:03 PM
sensei's Avatar
sensei
My point was that assuming you tested cylinder 4 last, you could have gotten good readings for cylinder 1-3 and a leaky gauge (or stuck check valve) on #4, that's why I'm saying to go back and test 1,2 or 3 again to see if you get the same numbers as before.
Old May 3, 2004 | 10:17 AM
shivers's Avatar
shivers
Moderator Alumni
I guess I should have clarified. I got 225 on cyl 1, 2, and 3. Then I tested cyl 4 multiple times. After that I went back to cyl 1 to retest to make sure the gauge was working. I got 220 that time ... so I think that shows the gauge is working correctly.
2005 s2000
Old May 3, 2004 | 10:23 AM
sensei's Avatar
sensei
Default compression
Ok, you and I have the exact same thought pattern...oh well, too bad about cyl 4
Old May 3, 2004 | 06:19 PM
shivers's Avatar
shivers
Moderator Alumni
Default Update ... re-test
So I did my original test with the engine cold ... which I've learned was incorrect. I did a re-test again tonight at normal operating temps. Results were as follows:
cyl #1 - 230
cyl #2 - 230
cyl #3 - 230
cyl #4 - 230
Looks like everything is normal. *shrug* Anyone who reads this, learn from my mistake ... do your compression test with a warm engine. Thanks to those of you that offered advice.
2005 s2000
Old May 4, 2004 | 05:24 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
hahaha... man you were worried for nothing. That sucks.
Glad it worked out.
NC Type R
4
Feb 17, 2004 05:49 AM
speed614
Engine Swaps, Tech & Tuning
2
Sep 4, 2002 07:04 AM
speed614
Aug 21, 2002 09:53 AM
