Was wondering how much i should expect to pay for this turbo setup?
Old Apr 23, 2004 | 01:22 PM
brand0n's Avatar
brand0n
Default Was wondering how much i should expect to pay for this turbo setup?
Drag Gen 4 turbo kit w/ intercooler and manifold
Chrome pipes
Deltagate westgate (7psi spring)
Vortec FMU
Fuel pump
Fuel filter *
Greddy blow off valve
Apexi turbo timer *
Apexi VTEC air/fuel controller V.2 (VAFC II) *
Autometer boost gauge
Missing map sensor link
NGK spark plugs *
NGK spark plug wires ( blue) *
Golden Eagle turbo oil feed kit
* = New
Old Apr 23, 2004 | 04:33 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
I'd say about $3500-ish.
However I would skip the FMU, VAFC and Missing Link.
Instead I would do the "build your own turbo kit" dealie that importparts.com started recently, with the following:
- DRAG Air Filter Kit w/ filter
- TurboXS RFL Blow-Off Valve
- DRAG 2.5" Downpipe
- DRAG Piping Kit
- DRAG B-Series Cast Exhaust Manifold
- Set of 4 RC Engineering 440cc Saturated Fuel Injectors
- Hondata S200B
- Walbro 255lph-HP In-Tank Fuel Pump
- Precision 350hp (26.75"x6.2"x3.5") Intercooler
- Misc. Hardware Bolts, Vacuum line, Fittings, etc.
- Stainless Steel Oil Feed and Return w/ Fittings
- Turbonetics T03/T04E Turbocharger
- Tial 38mm 0.5 BAR (7.25psi) Wastegate
All for a total of $3470.
If your car is OBD2, you'll need a set of wire clips for the injectors and they run 10 bucks a pop, plus a plug-in harness for the Hondata which is like $115.
Old Apr 23, 2004 | 04:55 PM
brand0n's Avatar
brand0n
so if i can get the above for 1600$ i should go for it..?
Old Apr 24, 2004 | 12:45 AM
s1ngle's Avatar
s1ngle
clutch slipping boost
my turbo setup will have cost me about 400-450 when its all said and done.
Old Apr 24, 2004 | 11:18 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
In a word: yes.
Old Apr 24, 2004 | 12:21 PM
Atheist's Avatar
Atheist
Just inspect the turbo very carefully, and if you dont know much, have someone else do it. Its important that it has no shaft play.
sho akkord
Dec 25, 2003 12:53 PM
blaus
Engine Swaps, Tech & Tuning
Sep 27, 2002 08:39 PM
sho akkord
Jul 19, 2002 11:11 PM
