B Series Parts List?
Old Apr 20, 2004 | 05:43 PM
The G2 Racer's Avatar
The G2 Racer
Want Boost!
Default B Series Parts List?
Just want to make sure I have all the parts needed for a B18B swap in an EG correct. I searched but need some help still.
Brackets: 94+ Integra, all even rear or no?
Distributor: What year/car?
Intermediate shaft and axels: 94+ Integra?
Shift Link and Shifter: 94+ Integra, Civic and teg stock shifters are swappable right?
Anything else I need? Do I need a different MAP sensor, throttle cable, different fuel injectors?
I'm going to upgrade to a Teg radaitor so what hoses do I use?
Anything else I'm missing, everything else just bolts up or plugs in? Like engine wiring harness just plugs in or do I have to mod it?
Thanks guys.
Old Apr 20, 2004 | 06:46 PM
Im@ge's Avatar
Im@ge
So ugly it hurts..See?
you do have the motor, right? :chuckles:
Old Apr 20, 2004 | 08:15 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Mounts: all teg, but the upper tranny mount will work from your civic
Distributor: Depends, if you have an OBD2 motor and you want to make it OBD1 then you need a B18B OBD1 distributor and OBD1 injectors with an OBD1 engine harness. If not, you need a B18B OBD2 distributor and an OBD2 engine harness. Even though your car is OBD1, the OBD2 engine harness will plug right in. I have an OBD2 engine & harness on my OBD1 car.
Axles/half-shaft: any Bseries
Shift linkage: Bseries
Shifter: civic or teg will work fine
Radiator: if you're going teg radiator, you need teg hoses. The Civic hoses are smaller so it will be harder to get them to fit the motor and the radiator. Teg will fit perfectly as the radiator and motor inlets/outlets will be the same size.
hih dude!
Old Apr 20, 2004 | 08:21 PM
The G2 Racer
Want Boost!
Thanks bro.
The engine will be ODB1 so I need an ODB2 dizzy and engine harness?
Or does the obb1 stuff work?
Old Apr 20, 2004 | 08:39 PM
westcoaststyle
As long as the harness, distrib & injectors are OBD1 you'll be fine. :goodjob:
Old Apr 20, 2004 | 08:43 PM
The G2 Racer
Want Boost!
Sweet! :thumbsup:
Thanks man.
Old Apr 20, 2004 | 08:47 PM
westcoaststyle
NP, glad I could help out! :wiggle:
Old Apr 20, 2004 | 09:52 PM
slammed91-hatch's Avatar
slammed91-hatch
need obd1 ecu too
Old Apr 21, 2004 | 03:58 AM
westcoaststyle
I thought that was a given. :dunno:
Old Apr 21, 2004 | 06:00 AM
EGteknikhatch's Avatar
EGteknikhatch
Team Teknik
i thought on the radiator you need a b16 top hose and a b18 lower hose? I could be wrong... but yeah...
