engine hesitation
Old Apr 16, 2004 | 09:29 PM
shawn_crx8891's Avatar
shawn_crx8891
Default engine hesitation
ok, here's my problem: i have a b16a and i have a problem with it hesitating when i give it gas, usually going up hills/around turns/revving out slowly. i have replaced the air and fuel filters, installed a 255lph fuel pump, and an adjustable fuel pressure regulator. i was thinking it was the fuel pressure, but increasing it didn't help. i noticed when i installed the fuel pressure gauge that the pressure only increased about 2 psi when i revved the motor, and it wasn't really a solid 2 psi, it was more like the needle bouncing around. i thought that it should increase more than that, but i don't know. another thought was that the throttle position sensor wasn't adjusted properly, since i took it off when i swapped the engine. i really don't know what the problem is, so any help is appreciated. thanks.
Old Apr 21, 2004 | 04:47 PM
s1ngle's Avatar
s1ngle
clutch slipping boost
as for the fuel, that sounds about right. It really only bounces up a few psi when i rev it.
what kind of exhaust are you running?
Old Apr 22, 2004 | 08:35 AM
shawn_crx8891
i have 2.25" with a 12" resonator and an hks hi-power muffler. i tried turning my fuel pressure up to about 40 psi and it magically began to rise about 4 psi when i hit the throttle like it should. i'm beginning to think i have a vaccum leak or a sticking fuel pressure regulator. sometimes it's fine and sometimes the hesitation is really annoying.
jaje
News & Rumors Archives
Feb 17, 2004 05:42 AM
s1ngle
92+ Civic/EL & Del Sol
38
Dec 30, 2003 12:09 PM
Tirod
31
Mar 3, 2003 05:13 PM
kustomdesignz
Dec 16, 2002 09:02 PM
jaje
13
Aug 27, 2002 09:52 AM
