Quick swap info needed....
Old Apr 16, 2004 | 04:27 PM
Edollasz's Avatar
Edollasz
Default Quick swap info needed....
Yea...I own and drive a 97 civic DX, and i want to know if i can just bolt a d16z6 vtec, d15b vtec, or just any d-series vtec head, or engine, right up to my car without any problems. Like if my 5 speed tranny would work with it, or if i needed to do any modifications.
I mean...my first thought was, that of course there should be no problems. But as u can already tell, I'm still learning, and even though it isnt a big swap, i want to make sure im doing the right thing.
So id like it if ne one can help with some feedback. Positive or negative.
Old Apr 16, 2004 | 04:41 PM
bambbrose's Avatar
bambbrose
I would stick to a d16y8 head because it is designed to work with an obd2 ecu. you will also need the ecu for the d16y8
Old Apr 16, 2004 | 05:18 PM
theguy386's Avatar
theguy386
I am tehguy... OH YEAH!!
The answer to all that is "yes"
you should have no problem swaping any of those in
Old Apr 16, 2004 | 08:00 PM
honura's Avatar
honura
Seni
Yeah you should have no problems. Even if you get a 92-95 motor your just gonna have to change the Distro, injectors. But yeah those swaps are simple and quick.
Old Apr 17, 2004 | 08:15 PM
Edollasz's Avatar
Edollasz
Ohh yea...One more thing
Im thinkin about a B16a1 swap. Is it worth it or should i save up some more money for the second generation b16
Old Apr 17, 2004 | 08:18 PM
honura's Avatar
honura
Seni
Does'nt really matter if it's newer or older. As long as the motor is in good shape. Newer is better but not in all cases. Goodluck man!
Old Apr 18, 2004 | 08:07 AM
Andy's Avatar
Andy
Hybrid Forum Moderator
I would recommend you stick with a D16Y8 engine if you plan to go with a D-series swap. I wouldn't bother with just a head swap unless your in the mood to learn to do that sort of stuff. The lower compression pistons of your non-VTEC engine will hurt your final power output. The shorter gearing of your non-VTEC engine will also hurt performance. Here's an interesting link you should read.
https://www.honda-acura.net/forums/s...d.php?t=126268
I don't know if his issues were ever resolved but those are some of the pitfalls of trying to bolt an OBD I engine into an OBD II chassis.
The same can happen with a 1st gen JDM B16A swap (what I'm assumign your refering to with a B16A1). Aside from the above mentioned OBD issues (a 1st gen B16A will be pre-OBD and even more of an issue as they are no pre-OBD to OBD II conversion harnesses), a 1st gen B16A will also have a cable operated clutch, as oppsed to your hydro setup that was in all '92+ Civic's. There are workarounds for this, I think HASport makes a conversion mount and adaptor but you'll be much better off saving your money and buying a later model engine.
Old Apr 18, 2004 | 05:47 PM
Edollasz's Avatar
Edollasz
:thinking:
Old Apr 18, 2004 | 05:49 PM
Edollasz's Avatar
Edollasz
iight fellaz.....It might take a while, but i think im gonna go for the b16a2 swap.
Nothin but more overtime at work to get there though oh well....
and oh yea, thanx
Old Apr 18, 2004 | 07:23 PM
Andy's Avatar
Andy
You could make an older engine work, but I honestly think in the long run, you'll be better off with the B16A2 (just to clarify, a B16A2 is from a '99+ Civic Si). Here's a good site with some info to help you research the swap itself and what you'll need.
http://www.phear7imports.net/subs/btroop/trey/6gen/
SlowRider
Jan 23, 2004 10:29 AM
yun cheezie
Engine Swaps, Tech & Tuning
Jun 8, 2003 05:04 PM
yun cheezie
Accord
Jun 8, 2003 03:26 PM
yun cheezie
2
Jun 8, 2003 12:12 PM
