h22a into integra
Old Apr 7, 2004 | 07:14 PM
ls_101's Avatar
ls_101
integra fs
Default h22a into integra
i was thinking of swapping the h bomb (h22) into my 99 integra, anybody done this before and know how much work it will be and is it worth it?
File Type: jpg
Old Apr 8, 2004 | 07:57 AM
AccordSleeper's Avatar
AccordSleeper
Former H22 Accord Owner
in a civic/teg a H22 is sick. the only problem is finding a nice low mileage USDM 99-01 H22 to make everything legal. or you could always go with an older JDM motor and switch to OBDI, but since your car is not that old i would figure you would want a motor closer in age to your car.
Old Apr 9, 2004 | 04:06 PM
H22ATeg's Avatar
H22ATeg
1995 H22A Integra
I got a 94 Teg with a H22A. This is a rocket. Cost about $6000 with the motor to be installed.
Old Apr 14, 2004 | 09:23 PM
Brad's Avatar
Brad
wooo nascar!
i'm doin it!
by the end of the summer (i hope)
Old Apr 15, 2004 | 08:36 PM
ls_101's Avatar
ls_101
integra fs
i hope to by end of summer to, my friends lude just went into the shop, h23/h22 hybrid, all internals, 12:1 comp,should b sick
Old Apr 18, 2004 | 01:40 PM
KKTPP's Avatar
KKTPP
with a h22 in a integra.. what would the 1/4 times be?
Old Apr 19, 2004 | 10:24 PM
Brad's Avatar
Brad
wooo nascar!
low 14s, mid-high 13s depending on mods and driver.
Old Mar 18, 2005 | 02:54 PM
x-1's Avatar
x-1
I will be doing one next week. I will let you know how it goes.
I got a 98 gsr droping a 2000 h22.
Old Mar 18, 2005 | 06:54 PM
jdmh22agsr's Avatar
jdmh22agsr
Default teg h22 swap
yes its worth it i got in my 94 gsr.. i have an jdm h22a .... my best run is 12.6
with slicks and without slick i run low 13's... things you need..
-motor mounts ( i went with the best place racing )
-90-97 accord 5 speed manual shifter assembly
-custom axles ( i went with hasport will work with stock prelude intermediate shaft )
-rewire wireharness for you..you need the obd2 to obd1 conversion.. if you go with the 92-96 jdm h22a..
-radiator like fluidyne,koyo
-slim fan ( fal fan )because it real tight with the headers
-prolly have to replace your clutch upgrade it cus your gonna need it with all that power... u can upgrade your flywheel or resurface it..
-need to make custom exhaust to bolt on to headers
-custom intake but aem makes a hybrid for the complete swap
i spent alot of money on mines but it worth it and you can imagine if you went turbo..my mods are..
-place racing motor mounts
-hasport level2 axles
-act clutch and act 8.5 flywheel
-apexi worldsport exhaust
-hotshot drag 4-1 headers
-twm individual throttle bodies w/ high volume fuel rail and fuel pressure regulator and golden eagle vacuum canistor
-aem stand alone fuel management system
-fluidyne radiator
-fal dual fan
-rc 370cc injectors
-walbro 255lph fuel pump
-aem adjustable cam gears
-unorthodox racing ultra ss pulleys
-str cam seal
-dc sports upper strut bar and rear upper and lower strut bar
-dc short shifter adaptor
-b&m short shifter lever
-kms egr block off plate
-tein adjustable coilover system
-running stock internals top and bottom..
next step is......
-5 angle valve job with oversize 1mm valves
-crower stage 3 n/a cams
-crower stage 3 valve springs and retainers
-crower stage 3 oversize 1mm valve stems
-je pistons 11:5:1 pistons rings..bored at .50 over
-eagle h beam rods
-ge sleeves
-ge blockguard
Old Mar 21, 2005 | 04:25 PM
:chuckles: If the people from Team Integra hear about this, its to the rope with you! lol its sacrilege to put an H series in an integra... lol
im kidding h:
anyways it is possible to do, and in my opinion its worth it....the question u ask have been answered so yeah goodluck to ya if you do it
