nos brand nitrous install
Old Mar 29, 2004 | 03:13 PM
93Nteg's Avatar
93Nteg
Default nos brand nitrous install
I recently purchased a nos dry kit from one of my freinds, the only problem is that he doesn't have the installation instructions for it and I've been searching everywhere for some free installation instructions and I can't find them anywhere. If you can help me out i would appreciate it alot. P.S. i need some bottle bracketts, new jets and a purge kit if anyone is looking to sell.
Old Mar 29, 2004 | 06:50 PM
wedley2's Avatar
wedley2
bboy Wesley West
dont u just tap a hole into ur intake tubing? or u can buy the Zex air filter thing whr u can insert the jet at the top...
Old Mar 29, 2004 | 07:10 PM
93Nteg's Avatar
93Nteg
There is much more to it than that. I'm looking into a more detailed explanation involving wiring, mounting the solinoids, ect...
Old Mar 29, 2004 | 07:28 PM
H-Accord-22's Avatar
H-Accord-22
Duh
I think there's the DIY manual and pic on importtuner.com i think.
Old Mar 31, 2004 | 07:44 AM
93Nteg's Avatar
93Nteg
I checked out importtuner.com and i couldent find the DIY. Keep em commen guyz.
Old Apr 1, 2004 | 07:09 PM
93Nteg's Avatar
93Nteg
I need some info. keep on posting.
Old Apr 15, 2004 | 06:29 PM
93accord's Avatar
93accord
If it's a dry kit, it's a fairly simple install. Like said before you tap your intake and put your nozzle in there. You should only have one selonoid, if its dry, and to wire it you take one side and put it to a good ground. The other side you would want to run to a relay. The relay should then run to a throttle switch, to a constant power, and to a ground. The the throttle switch should run to a arming switch inside the car, which will run to a keyed 12 volt. Mount your bolt brackets, and connect your nitrous lines, and your good to go.
From credibility: http://board.hondasociety.com/showthread.php?t=75173
99accord520
Accord
9
Nov 8, 2003 04:41 PM
SSCivic
92+ Civic/EL & Del Sol
14
Jul 7, 2003 10:55 AM
1flossedteg
Jun 24, 2003 06:04 AM
jigga008_99
Apr 23, 2003 07:06 AM
MartyMarGSR
Engine Swaps, Tech & Tuning
25
Nov 16, 2002 05:00 PM
