B-16 clutch
Old Mar 27, 2004 | 02:17 AM
sekongen's Avatar
sekongen
Default B-16 clutch
I own a B-16 powered 91' Integra. For the last two months or so I have noticed my cluch slipping. I kinda put it at the end of a long list of things to do. Unfortunatly tonight when I got off work I found my clutch is pretty much completely gone. I barely got home. Anyways I did a forum search To see what clutch I need to buy (not sure if all b series clutches are the same). One guy said that the 92' 93' GSR clutch is what I would need not to sure what to do . Should I get a GSR clutch or a Del Sol clutch? Any help would be greatly appreciated
Old Mar 28, 2004 | 01:46 PM
Andy's Avatar
Andy
Hybrid Forum Moderator
For some reason, I remember reading that some first gen B16A's had a different spline count on the shaft coming out of the tranny than other B-series trannies. I'm not sure if that is true or not however (I'm assuming your B16A and tranny are JDM pieces). I haven't worked on a swap like that myself yet. I ran a clutchmasters stage 3 clutch in my '92CX / '95 B18C1 hybrid and I was very happy with it. I used a CM aluminum flywheel too. Here's the link for their site.
http://www.clutchmasters.com/shop/
I'd consider giving them a call or email them and ask a source directly. I'd recommend you buy from one of their dealers as you'll get a better price but they can probably tell you the best clutch for your application. Sorry I don't have more info.
Old Mar 28, 2004 | 02:03 PM
sekongen's Avatar
sekongen
Thanks Andy. I got a clutch now I need a flywheel. I think I am going to check them out(clutchmaster.com).
Old Mar 28, 2004 | 07:25 PM
Andy's Avatar
Andy
I was happy with mine. I believe it said it was 9 pounds with a replaceable steel friction surface. I only had it for a few thousand miles before my car was wrecked.
Just out of curiousity, what clutch did you buy and is it the same as any other B-series setup? I actually need a new clutch for my '98 EX daily driver (stock motor for now). I just started researching them.
Old Mar 28, 2004 | 11:41 PM
sekongen's Avatar
sekongen
I got an ACT stage 2. I think it was a little pricey and I heard some bad things about the design. But I was in a pinch and needed it asap. As far as compatability I am not sure but I think they are (b series clutches) the same. Im still trying to figure out if I can use any b series flywheel with the clutch I just bought. I will let you know if I find out though.
Old Apr 1, 2004 | 01:25 AM
Civic2Scooby's Avatar
Civic2Scooby
the first gen b16a's use a different clutch than the hydro tranny. I would recomend using a clutch/flywheel combo made for the b17a or b18a egines
AwwsChwA
Engine Swaps, Tech & Tuning
3
Apr 15, 2003 11:17 AM
98CoupeV6
Do It Yourself
Jan 17, 2003 05:11 PM
[hC]
9
Aug 21, 2002 12:03 PM
JackoliciousLeg
Jul 31, 2002 08:28 PM
sir_crx
6
Jun 23, 2002 02:31 PM
